Main Menu
avatar_NARSES2
Finished Entries
Started by NARSES2, February 04, 2025, 06:00:22 AM
BMP 100mm SP Gun
Dragon 1/35 BMP 1 with the skif 100mm BS-3 Anti Tank gun wedged in
Build Thread6
The tripple T
Ukraine ,,summer of 2024 ..The Azov brigade are on a village clearing mission in the Donbas region after footage from a high altitude recon drone found several russian positions which were discovered which had been eluding the Ukrainian forces .
The main targets of the mission are the very well hidden MLRS ( Multiple Launch Rocket System ) vehicles which the Vampire drones were having a hard time dropping bombs on ...during the first attack the Azov brigade destroyed 3 BM-21 rocket systems and there ammo dumps which for some extremely stupid reason were within 10 metres of the vehicles themselves ...still the Azov soldiers  were not complaining .
But ,,in the next position number for things changed ..complaining wasn't heard ,,laughter ,,a ton of laughter was heard when what they discovered came into view ...the tripple T as the troops nick named it ,,pictures were taken and sent back the the head shed for them the see for themselves when the messages they received were not believed ...so impressed were they that orders were put in place to recover this thing to be put on display in Kiev for everyone to laugh at .
DSCF5096 by Phill Harrison, on Flickr
DSCF5095 by Phill Harrison, on Flickr
DSCF5098 by Phill Harrison, on Flickr
https://www.whatifmodellers.com/index.php?topic=53733.msg1076401#msg1076401
The Chaos
#17
The Mammut are finished, have fun.
Build here https://www.whatifmodellers.com/index.php?topic=53713.0
German 13.0cm SD.Kfz 188 Selbstfahrlafette "Sturer Anmil"
Heres the link
https://www.whatifmodellers.com/index.php?topic=53683.60
Russia ...the Siberian steps ..summer ...sitting in a well prepared firing position sits the  German 13.0cm SD.Kfz 188 Selbstfahrlafette "Sturer Anmil"..a true monster of a tank hunter ,,with a Rheinmetall PAK 45 130mm gun with a killing range of 2.5kms firing the APDS round .
Now how did this come around ...well in Germany in 1943 an order was issued for a new tank destroyer as the Allies were now fielding tanks with much tougher armour and more powerful guns .
Orders were issued to Alkett,,MAN, Porsche and Henschel for a prototype as soon as possible ...which at that time of the war meant yesterday .
All manufactures apart from Henschel and Rheinmetall-Borsig who would join Henschel had no chance to build a new prototype as they were very busy with their own orders to deal with producing vehicles for the German war effort.
Problems began pretty much right at the start ...engines where in very short supply so plans changed right there when it was decided to run two engines instead of one ..that intern meant a new gear box had to be built to be able to link the two engines  together .
The original engine was going to be the new Maybach HL230P30 700hp ment for the new Tiger ll which was under development at the time but with so few engines actually built and time against them two Maybach 120TRM 300hp engines would be used instead .
Combined there two engines would be at least 100hp below the original engine of choice which would lead to other problems they didn't know about yet .. cold weather would suck even more horse power from these two engines which lead to the vehicles top speed alittle under 17kms per hour on hard ground ..in soft mud this would go below 10kph .
The weight was also going to be an issue with the extra engine and all of its ancillaries aswell taking the overall weight up to the 55ton mark when everything is taken into account .
The weapon of choice was going to be the Rheinmetall Pak 45 130mm anti tank gun ...this weapon was a developmental version of the  Pak 44 128mm AT gun ,,it was ordered by Hitler to be used as he felt ( and we all know this ) that bigger is better ...not taking into the fact of course that the guns rounds were now 2mm wider and 37mms longer which increased the weight by nearly 4kgs ,,taking the overall weight now up to 41kgs for the warhead alone,,which intern gave this vehicle a pathetic amount of onboard ammo of 12 main gun rounds .
In combat and this came to the surprise of no one that the Anmil  was an extremely heavy, unreliable Pile Of Steel ...the main gun ,,even though it would kill anything the guns rounds would hit,,the situation of the ammunition supply was a nightmare as the Allies kept bombing the factories where they were made and because these rounds were only made by one factory ,,this became a massive problem to the point that at one point 9 out of the 10 vehicles made were in hiding dew to not having any ammo for there main guns ,
Not like this was much of a problem really as there was an extremely good chance it would break down at some point anyway with its mechanical unreliability ..the final drives would shred gear teeth if you tried to turn to shape at speed..the transfer case which sends power to the gearbox would split its case for some unknown reason which wouldnt happen to often as the left hand side engine had a tendency to overheat ...another problem which never got a chance to be overcome .
The    Selbstfahrlafette "Sturer Anmil" ended the war the same as pretty much most German armoured vehicles did ...either destroyed or captured to be later blown to bits on the ranges at Allied  tank gun ranges .
DSCF5137 by Phill Harrison, on Flickr
DSCF5140 by Phill Harrison, on Flickr
DSCF5139 by Phill Harrison, on Flickr
Glenn Gilbertson
Build thread at https://www.whatifmodellers.com/index.php?topic=53847.0
RAFF-35
There are a higher than usual amount of armoured entries into this group build, and I'm here to add one more. The Saint-Chamond of the Expédition Antarctique Française (1919-1921).
Why was it such a bad idea? It was slow, unreliable, uncomfortable, inefficient and under equipped to survive in the harsh Antarctic environment. Plus the crew painted it silver, which made it incredibly difficult to find in a blizzard.
The build photos and back story can be found here;
https://www.whatifmodellers.com/index.php?topic=53771.new#new
nönöbär
Saab S-100
In the early 1950s, the Saab S-100 emerged as a pioneering jetliner, a collaboration aiming for smaller Scandinavian airports. It boasted a high-wing design and four engines for unpaved runways. Despite its innovation, two fatal crashes in 1958 exposed a critical flaw: high angles of attack disrupted airflow to the rear engines, causing flameouts and unrecoverable stalls. All delivered aircraft were returned and ultimately scrapped, serving as a cautionary tale. The S-100 remains a largely forgotten chapter in early jet aviation, its demise influencing future aircraft designs away from high-wing, rear-engine configurations.
More can be find here: https://www.whatifmodellers.com/index.php?topic=53725.45
And even more on the Scratchbär site: https://www.scratchbaer.de/whatif-aircraft/sweden/saab-s-100/
PFJN
#24
Hi,
Here is my entry and intro to my build.
Based on the old adage that "An Army Marches on its Stomach" and the thought that special forces may require special foods, an elite force of soldier-chefs were formed into the "Culinary Combat Commados"(CCC), a unit known for the ability to "whip you on the battlefield as easily as they can whip you up a a gourmet meal"
The figure below shows a member of the CCC brandishing his Compact Cast Iron Combat Skillet, Ballistic Cloth Battle Apron, Tactical Toque du Chef (Chef Hat) and a Wine and Cheese Platter.
                Liberte' - Fraternite' - Gastronomie
[Good Food - Good Freinds and Freedom] (more or less) ;)
Joe CalPo
The accidental hero of WW2, HMS Bifters.  Through a mistake in identity at the Admiralty she was armed and sent forth to battle Nazi submarines, for a little while.
Her full story is in this thread: https://www.whatifmodellers.com/index.php?topic=53701.0
CammNut
Royal Navy Fleet Air Arm Rockwell FV-12A Sea Sabre F.1
Fit to be tied after losing its big deck carriers and seeing its Mach 2 Phantoms transferred to the Royal Air Force, the Royal Navy resolutely refused to accept the subsonic Sea Harrier as an adequate fleet air defence fighter.
The Fleet Air Arm was adamant that it needed a supersonic aircraft to equip its new V/STOL carriers. But with the earlier cancellation of the Hawker P.1154, a navalised version of the much smaller and slower Harrier was all the British industry could muster. So the Navy went shopping.
The only supersonic V/STOL aircraft  even remotely available was in the U.S., the Rockwell XFV-12A. A prototype had been built using parts of the A-4 and F-4 to save time and money. After a troubled development effort, the aircraft had finally demonstrated its ability to take off vertically, accelerate close to Mach 2 and return to a vertical landing.
The XFV-12A used a technology called the thrust-augmented wing. For vertical flight, the exhaust from the engine was diverted and ducted to augmentor flaps that opened to create full-span slot nozzles in the canard and wing. Here the high-velocity exhaust air was entrained and "hypermixed" with a much larger amount of ambient air, augmenting engine thrust and enabling vertical takeoff and landing.
Each slot nozzle had a lower pair of Coanda flaps and an upper "hypermixer" flap. The angle of these augmentor flaps could be varied to increase and decrease the exit area of the slot nozzles to control lift as well as pitch, roll and yaw.
To transition from thrustborne vertical flight into wingborne forward flight, the flaps were first tilted to vector thrust then closed. With the flaps closed, all the engine thrust went to the aft nozzle and the aircraft could go supersonic. Tilting the flaps also enabled the XFV-12A to perform short takeoffs and landings.
Development was arduous. At first the XFV-12A could not lift even its own weight, but thousands of hours of engineering work improved the system to the point where the aircraft could takeoff and land vertically and go supersonic, albeit with no weapon system onboard.
It was just a one-off prototype and its intended customer, the US Navy, was losing interest in supersonic V/STOL with budget cutbacks to its planned fleet of Sea Control Ship mini-carriers. That did not deter the Royal Navy, which launched a full court press to force the British government to acquire the FV-12.
Admirals went on morning TV to warn that Great Britain risked losing its centuries-long mastery of the seven seas. A top-secret analysis was commissioned, circulated confidentially and leaked to the press with the preposterous premise that Argentina could invade the Falklands. And Britain, its Navy equipped only with subsonic Sea Harriers that were no match for Argentina's supersonic Mirages, would be unable to retake the islands. It was a fiction that worked.
The UK government buckled and, ignoring all the warning signs, an initial batch of FV-12s was ordered. BAC, anxious to have a V/STOL rival to Hawker's Harrier, agreed to anglicize the U.S. fighter and support it in service. Ferranti's Blue Fox radar, planned for the Sea Harrier, and British Aerospace Sky Flash missiles were fitted as a sop to UK industry. Development was completed, at a rush, and the Sea Sabre F.1 joined the Fleet Air Arm.
And then it all went horribly wrong. First, the FV-12's performance was marginal at best. With all the ducting and flappery, the volume for fuel was limited and so therefore was range. So limited that an editorial in Britain's Flight magazine dubbed the FV-12 "the Royal Navy's Lightning".
Second, reliability was terrible. The technology was immature and testing has been rushed to meet the unrealistic deadline of its only customer, the Royal Navy. The heat-stressed ducting cracked, the complicated control system failed and the aircraft required constant maintenance, a nightmare at sea.
Third, it was unsafe. If a duct or flap failed in vertical flight, thrust from one of the four "lift posts" on the canard and wing was lost and the aircraft became uncontrollable. Several aircraft were lost. Not all of the pilots survived.
Eventually the Navy was forced to withdraw the FV-12 from service prematurely, leaving its carriers without any fixed-wing aircraft. But Hawker had continued work on the Sea Harrier under a cloak of secrecy and was able to get the aircraft into service relatively quickly...just in time for Argentina to invade the Falklands.
LeA Mirage IIIVB
By Weaver
The obscure French company Lorelle et Ardee design a V/STOL aircraft around a Mirage F1 airframe but get sent a Mirage IIIC instead, a month before the Paris Air Show. They build it anyway, intending only to show how the engine would fit in an airframe, but having forgotten to print the explanatory notices and press packs as well, they get evicerated by the press.
Build thread: https://www.whatifmodellers.com/index.php?topic=53687.0
killnoizer
The unfamous italian twin prop construction of the Fiat CR 32 .
The italian construction genius  Doctore Enrico Condomi offered this owerpowered version of the standard fighter to Mussolini in 1937 . The Duce was heavy amazed about  this cheap solution to get a double prop fighter with one engine,  but the test flights were a desaster  :wub:
I could not show this before the deadline, because the website was not reachable this evening.
                     ~ π ~
VDPM Hannover / Germany
