avatar_Dizzyfugu
[email protected] +++ 1:72 ббс-I armored aerosan; Karelian Isthmus, winter '44/45
Started by Dizzyfugu, December 01, 2024, 02:18:37 AM
Early post. Work is already in progress but there's nothing to show yet. But this one will be a bit ...scary, at least from a "Imagine, what if..." perspective.
Stay tuned.  :mellow:
Aerosan is a good guess, but it's ...bigger.  :angel:
Finally, there are things to show from this ...thing. First of all the major ingredients/donor banks, it's more or less a kitbashing project with some add-ons:
1:72 Tupolev BBS-1 (бронированные боевые сани/'Armored Battle Sled') aerosan
by Dizzyfugu, on Flickr
Things started slowly, with the OOB KV-1 turret that will also be the main armament of this aerosan behemoth:
The main body consists of a Soviet armored draisine from Trumpeter, but I found the body to be too long and symmetrical for my plans, so that I took out a ~2cm plug and glued everything back together...
...with this "core" result:
More to follow soon! Muahahahaha!  :wacko:
More add-ons, since we need propulsion. The engine comes from a MisterCraft PZL 23 bomber, an ugly one-piece blob that I never expected to find a good use on a model. It was modified to look a bit more delicate, and at its rear an extension fairing was added, partly consisting of a piece from a plastic ballpoint pen casing.  ;)  The pusher prop consist of a reversed F8F piece, with a metal axis and a spinner transplant from an Italeri F4U.
If this does not look scary yet...?  ;D
If this thing will ever move it's going to need a bigger motor! Much bigger. Or maybe a couple of them. Just my tuppence! Yes we did watch Mary Poppins!
In 72nd scale that's gonna be a bloody big engine and that propeller is massive in that scale ..yeah that should move it but it being russian that's no guarantee it will for long  ;D  ;D
It would be damn impressive to see moving around .
Bugger!!! ..that prop has me wondering now just how big it would in the RW 😆
It would be MASSIVE! And the scariest thing is that it has NO physical brakes (AFAIK no aersoan had any?), just a reversible prop that I gave it in my imagination. Imagine a British WWI30 ton tank on ice going 50 mph...  :wacko:
Quote from: Dizzyfugu on December 04, 2024, 10:14:46 AMIt would be MASSIVE! And the scariest thing is that it has NO physical brakes (AFAIK no aersoan had any?), just a reversible prop that I gave it in my imagination. Imagine a British WWI 30 ton tank on ice going 50 mph... :wacko:
I can, with considerable difficulty, imagine  "Little Willie"  on ice,  but my imagination adds a pair of heavy duty Admiralty-pattern anchors as an emergency braking system.
Quote from: Dizzyfugu on December 04, 2024, 10:14:46 AMIt would be MASSIVE! And the scariest thing is that it has NO physical brakes (AFAIK no aersoan had any?), just a reversible prop that I gave it in my imagination. Imagine a British WWI30 ton tank on ice going 50 mph...  :wacko:
Yeah same thoughts..like a 20 foot diameter sort of massive  :o
I love it 😀 😍
As for brakes you just cut power or feather the prop and have deployable ice brakes under the monster which bite into the snow or ice ..might work 😆
More things to show - the aerosan slowly rather looks like a Warhammer Orc vehicle...?
Suspension has been mounted, taken wholesale from the 1:35 kit, even though I had to lengthen some of the control struts.
While safety is not an inherent design feature of this thing I thought that the prop needs some protection, so I started to scratch/construct a cage for it from soft iron wire, and his ugly intersections behind a pair of fins (actually sections from an 1:72 Panzer IV side skirt). Turned out better that hoped for.  :angel:
In parallel, the four skis were put together, too - again taken OOB from the small 1:35 aerosan kit:
The protection would be to prevent the prop from getting damaged by a steel helmet (with a live human head inside).
