avatar_retro_seventies
more seaplanes
Started by retro_seventies, April 01, 2005, 09:01:04 PM
retro_seventies
#15
the bronco that i did had a hull and was pretty fugly - i think that popping floats on her would be much more attractive than this little barrel:
But it looks intriguing!  Would the prop-tips hit the water though?
retro_seventies
probably.
i lifted the booms and inverted the engines, but they still look a pinch low - i was thinking gull wings for the "version 2" of this one...maybe with those she'd be a winner...
elmayerle
You'd definitely want to invert the engines in any case to minimize spray ingestion problems.  The T76/TPE331 is an easy one to do that with, though I'd take pains to make a short exhaust duct as it's my understanding that Swearingen on the later Merlin and Metro variants found that the long exhaust pipe definitely caused problems and difficulties.  I like the idea of a gull wing myself (consider the Piaggio P.166 as an example for your efforts).
--Jane Wagner and Lily Tomlin
upnorth
If I ever find Italeri's old 1/72 C-119 Flying Boxcar and Airfix's old 1/72 Shorts Sunderland, I'm going to try kitbashing an amphibious C-119.
If I can get the hull just right, I should be able to adjust the C-119's landing gear so that the mains will keep the hull clear of the ground and I'll build a tail wheel unit to replace the nose gear.
My two initial thoughts would be as early to mid 60's RCN machines. Either with and ASW fit or for rescue work.
Further thought would be after RCN retirement modified for fire killer use. A scooper to predate the CL-215.
I figure the hull on that thing should be deep enough that there should be no prop to water interference issues.
My Blogs:
Glenn
How about a He-111B/C with twin floats. (Lufthansa)
Siebel Si-204 floatplane. (Italian Navy)
B.P. Defiant F.A.A. (twin floats)
G(lyn)n
Jschmus
#21
If I remember correctly, one of the stipulations of the original Tri-Service LARA RFP was that the plane had to be capable of operating on floats.  I have only ever seen drawings of the Bronco with floats, but I don't believe this was ever tested operationally.
Here's the drawing from Air Progress:
Bronco on Floats
upnorth
QuoteHow about a He-111B/C with twin floats. (Lufthansa)
G(lyn)n
Don't tempt me with that Siebel 204 concept, I've been fighting the urge to buy Kopro's 204 kit for months.
I was also considering picking up Smer's LeO 145 kit and puting floats and late 40s Air France markings on her so she could do short passenger and freight runs across the Mediteranian.
My Blogs:
Glenn
Just think what it would have been like, if Hollywood had built more planes for movies?
I'm looking at the T-6, I mean it's been in 100's of movies/ TV shows, and if they put one on floats, they could make 100 more!
T-6/Arado Ar-196
T-6/Aichi E13A 'Jake'
and there is this Northrop floatplane used by Norway.
The ideas are endless.
Lyn
QuoteIf I ever find Italeri's old 1/72 C-119 Flying Boxcar and Airfix's old 1/72 Shorts Sunderland, I'm going to try kitbashing an amphibious C-119.
ebay!   ^_^
retro_seventies
ebay is whore - a cheap temptress, singing the siren's song, almost magically sucking the money from our bank accounts  :ph34r:
great though, aint it?
