avatar_Old Wombat
A Dark Christmas Knight - FINISHED!
Started by Old Wombat, October 07, 2024, 05:57:48 AM
Possibly "Grim" would be a better word than "Dark", we'll have to work that out. ;)
So, having put the Malkara (M3) Grant aside for now, I have put the Pegaso Models 75mm (1/24) "Northern Wandering Knight XIV Century" on the work bench.
The image on the box cover is about as close to an instruction sheet that this figure comes with, so construction is a matter of common sense (which, luckily, I have a little bit of), trial-&-error, & a smidge of good luck.
The build will be as close to "OoB" as that combination will allow & it is the painting that is going to be the What If... part of this build.
My aim is to blend a number of styles into one (hopefully) cohesive whole.
First influences will be various traditional Santa Claus';
With a few warrior (Santa) influences;
But no Samurai Santa inspiration (although, it is kinda cool);
And absolutely NO weird, deformed AI generated Warrior Santa creepiness, either! :o
Currently in the process of cleaning up the minor flash/casting marks on the parts - a lot less obvious than on most plastic models but much more difficult to get rid of (a quick scrape of the ol' No.11 just doesn't do the trick on white metal). :rolleyes:
I am much looking forward to viewing the results of advanced WOMBATTRY in regard to this figure!
Quote from: Old Wombat on October 07, 2024, 05:57:48 AMPossibly "Grim" would be a better word than "Dark", we'll have to work that out. ;)
If you were doing Grim you would need a second one so you could do them as brothers  :rolleyes:  :angel:  ;D
Thanks, gentlemen! :bow:  :bow:
Quote from: Gondor on October 07, 2024, 07:24:25 AM
Oh, good grief! :banghead:  :banghead:
Chris, where's The Book? :unsure:
Joe CalPo
Quote from: Joe C-P on October 07, 2024, 07:54:12 AMNONE SHALL PASS HO HO HO!
Or,
"You shall not pass!" But that leads into a wizard Santa.....
Did you mean 'What If...' or 'What The...'  ;D
Quote from: Rick Lowe on October 07, 2024, 09:33:13 PMDid you mean 'What If...' or 'What The...'  ;D
Oh if ya think is gonna get dark or weird I'm hoping Womby has alot more dark and weird in store 😆
This will hopefully kick me in the butt to start playing with a figure I have in mind 😅
Having "dark" and "knight" in the same sentence (even if separated by "xmas") makes me expect Batman.
However, rendered in German its a different matter.
Dunkler Weihnachtsritter
Quote from: kerick on October 07, 2024, 08:16:40 AM
Or,
That way lies on the path to a discussion about swallows & coconuts, followed later by a bridge-keeper falling victim to his own challenge.
Speaking of which; Could anything be more weird than the subject of this article;
https://www.openculture.com/2019/03/killer-rabbits-in-medieval-manuscripts-why-so-many-drawings-in-the-margins-depict-bunnies-going-bad.html
A-anyway, clean-up is done.
Next is working out where to drill to fit the strengthening pins - they don't have to be super-strong but strong enough to hold the weight of the pieces firmly against gravity.
Having watched a few YT videos, & read a few articles, I'll be using Araldite (2-part epoxy adhesive) to fix everything together. CA seems to be common for smaller figures (gaming, older pre-resin, etc.) but epoxies seem to be the go for heavier builds like this one.
I'll be using Apoxy Sculpt to fill in any gaps, when I get that far.
Anyway, back to work tomorrow & I've been asked to start early (to fit an anklet to some bloke so he can catch a bus to wherever), therefore not much going to get done tonight.
Quote from: Old Wombat on October 08, 2024, 04:10:05 AM
Or,
Mentioned this in your blog Womby mate..soft brass wire ..ive used it in the past for white metal figures..it's kinda perfect ..easy to bend but strong enough to to hold a 1/16th metal Knight together and trust me..that was heavy .
1mm will work for ya  :thumbsup:
Quote from: Wardukw on October 08, 2024, 10:43:42 PM
Or,
I don't have brass wire but I do have some approx. 0.8mm galv. steel wire which should be fit for purpose.
Be a bit careful with galv wire. If you damage the zinc coating then it will rust and that might well play silly buggers with the white metal alloy casting. It's all a case of "might" as I don't know what the white metal alloy is.
