Ricks' Ramblings
Started by Rick Lowe, July 20, 2024, 06:33:31 PM
1/76 Hanomag Sdkfz 251/22D **real world**
Based on a Matchbox kit; the rear end, bonnet sides and front end were replaced with scratch parts to convert it into a D version.
The interior was altered with reference from the Osprey book on the 251, and the gun came from the Airfix 234 kit, on a scratch mounting.
Details from bits and pieces.
Humbrol Panzer Yellow with Red Brown camouflage, and a Black wash.
Could add markings at some stage, but then the late war stuff was pretty plain, so...
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
Catch up mode... love the Mal's Pistol.
Notch me up as a closet Brown Coat as well.
A very nice little Sdkfz 251/22 Rick matey  ;D  ;D
Be glad your not or was addicted to to WW2 german half tracks bud ,, i had all 25 versions of the 251 ,,and all the others ,,mate that's alot of models  :o  ;D
Thanks, fellas.
Phill - I do have a few still to do, in both scales... Some time...  ;)
#636
Heller 1/72 Hughes OH-6A Cayuse *Real World*
I read the Squadron Signal book "Gunslingers in Action" and from then on, I wanted a 1/72 Loach model. There wasn't one readily or cheaply available; so, I resigned myself to waiting and/or going without.
Then Heller released a range of Clic-Clac models, and in amongst them was a Hughes 500 which was close enough to 1/72.
Once I managed to get ahold of one, it was all go.
I basically only used the body, interior floor, front transparency, skids and most of the rotors.
The rest of the interior was scratchbuilt, and on the outside I opened up the transmission hole for the scratchbuilt main rotor shaft.
I cut out the doors as they usually flew without them.
Inspired by the 'In Action' book I added a couple of carbines and a bag of ammo magazines between the front seats, as well as some smoke grenades strung behind the front seats, and a box of grenades by the rear seat.
I shortened the skids' height and pinned them to the body.
I left off the D-model 'T' tail and made the correct earlier angled fin and brace.
I made a new main rotor hub and attached four of the five main blades to it. I also tweaked the tail rotor.
The gatling barrel is from the ESCI Huey kit with a scratchbuilt rear casing. An ammo box was cut down from the Huey's unit.
A Minitanks M-60 was hung from a piece of cotton.
Paint is Humbrol enamels and markings are from the spares box.
It seems to compare pretty well to the Italeri kit I got later, so I'm happy.
(I couldn't find a shot of the Heller kit, sorry...)
The book 'Low Level Hell' is also well worth a look.
That looks very good mate  :thumbsup:  :thumbsup:
Excellent job, Rick!  :thumbsup:  :thumbsup:
George the Cat
Sci Fi Drop Pods
A good friend is a big Battletech fan but he stopped playing it when Life Stuff took precedence.
When things went a bit awry for him and he stopped doing a lot of other things too, a couple of us decided to try and get him interested in wargaming again.
I thought something he could use as scenery, or mission objectives, could help.
I started with a couple of different sized single-serve rice cups. I screwed the bottom one onto a placemat, then scraped a hollow in a second one to allow for the screw head, and glued it on.
The rim of the lower cup was cut away to allow the upper one to fit, and a collar of cardboard was glued under the rim to fill the gap and give the two parts more area to grip.
That also saved on filler & sanding.
The legs are runner inserted into tubing, and fitted into holes cut into the cup; this was easier than trying to cut the legs to the correct angles.
The feet are buttons and circles of card.
I added detail from cardboard – hatches for the mechs to emerge from, weapon mounts.
The antenna farm on the top is a few pins and bits of wire stuck into half a toy truck wheel rim. With a bit of grooved card around the base, it fitted nicely into the indent in the cup.
I glued a bit of sand onto the bases and the models got a sprayed black base coat.
I didn't do any more painting, as I'm not sure which Clan or House he plays, so decided to let him choose his own colour scheme.
Same with any extra detail; he can decide what he wants, if any.
As I understand, he's recently started getting back into the game; but whether these helped or not I don't know and won't take any credit for.
But it's good to hear he's taking an interest again.
