avatar_Robomog
Push-me-Pull-you Spitfire. --- for Tophe
Started by Robomog, June 30, 2024, 08:56:32 AM
Quote from: Robomog on July 19, 2024, 03:22:51 AMWardukw :-  Good call on the floats, I think they would have made this build a lot more elegant, but, hey-ho, that's life  ;D  ;D
Kit :- absolutely!  As I have said before, you can't have too many drop tanks in your parts stash  :thumbsup:
Mog
Moggy I consider that a lazy way out fitting floats but as lazy goes I very happy about it 😊
I wanted a float plane build and I've got that  :thumbsup:  :thumbsup:
I definitely got a race plane kick going at the mo ..I will be building te twin engined Mustang and I very been laying it out in my squishy bit ..i even got a set of contra props for it ..well the blades ..it's going to be an entirely new experience scratch building a hub for it  :wacko:
Robomog
Woo!  scratch building a prop, respect if you pull that off
Could you not source a Spit 14 prop, or pinch one off a sea fury ? Or for that matter make a contra prop from two standard props like the Vertistang
by Robomog, on Flickr
Save a lot of time and swearing  :rolleyes:  :o  ;D
Mog
Robomog
Hi all
Finally finished the PSR (for now) and all the fairings for the undercarriage .....
It's off to the paint shop for the primer coat.
Thanks for looking......
Mog
That's looking magnificent already WITHOUT The paint!  :thumbsup:
Robomog
ericr
Robomog
Thanks guys
The Spitfire has had its first primer coat and as predicted its thrown up a few faults.
For example one side of the rear engine where it joins the fuselage has a noticeable concave section on one side and a small step on the other. Various small holes and scratches on the  booms and a little bit more smoothing required on the wheel pods.
Nothing major but annoying all the same  :-\
More when it happens....
Mog
Robomog
Hi all,
Priming and tidying up of the filler is done .
And the spray rig has been constructed, next job, COLOUR !
I'm spraying this one light blue much like the original Spitfire prototype .
Thanks for looking..........
Mog
I have to say, I think the spray rig is pretty good, too!  :thumbsup:
Must 'Take Inspiration from the Idea', as it were... ;)
Robomog
Thanks guys.
That spray stand was re-adapted from one I did for a Red Arrows Hawk, hence the pinky red colours.
Making a stand is a habit I got into when I took up spraying and sprue is a free medium to create it with.
Sometimes you have to get quite creative, almost a model within a model  ;D
The spitfire has its colour now and decals.
Just a coat of matt varnish and the undercarriage to sort out and it will be ready for presentation.
Watch this space..........
Mog
