avatar_Robomog
Push-me-Pull-you Spitfire. --- for Tophe
Started by Robomog, June 30, 2024, 08:56:32 AM
Robomog
#15
Thanks guys
First PSR session done and the air intakes fitted
Radiators fitted, I might fit a third depending on how the nose wheel solution resolves it self
The booms are nearly finished, I just need to add a little filler to level all the surfaces up
More when it happens.........
Mog
It is very cool 😎 😃
Needs contras  :wacko:  :wacko:
Like this one too... so many exotic builds in this GB
loupgarou
Quote from: PR19_Kit on July 12, 2024, 03:13:49 PMI DO like the look of this one.  :thumbsup:
YES. It will be pretty when completed.
Robomog
Thanks for the comments guys.
Started to attach the booms and came up with this........
Can anyone remember this configuration on other aircraft?
I was sorely tempted to run with this but the booms are too short and the inner tailplane would get shredded by the rear prop.
So back to the original plan.........
Both the booms are attached but are a bit flimsy, I'll need to add a bit of reinforcement
Thanks for looking....
Mog
😆 🤣 😂.. freaking love this 😀
I'm still thinking of a twin engined Mustang Moggy but one behind the other with contra-props...like the
Italian Macchi-Castoldi M.C. 72 ...that will look nuts and id still be able to have landing gear ⚙️  :wacko:  :wacko:
Robomog
#25
Hi all, working on the undercarriage now.
I've constructed a pod under each wing to house the man wheels which will fold forward. The pod will open to receive or let out the wheel and then close behind it so that the only doors open when the undercarriage is fully extended will be around the base of the undercarriage leg.  There is a fairing behind the leg to make things more aerodynamic.
I will need to work a similar construction for the nose wheel.
More PSR to smooth every thing out  (sigh)
Mog
Dude, that's looking sweet mate 👌  ;D
So glad I didn't have to worry about landing gear 😄
Robomog
Wardukw :-  Good call on the floats, I think they would have made this build a lot more elegant, but, hey-ho, that's life  ;D  ;D
Kit :- absolutely!  As I have said before, you can't have too many drop tanks in your parts stash  :thumbsup:
Mog
