avatar_The Rat
Swedish Navy DH.114 Heron
Started by The Rat, April 05, 2024, 10:49:35 AM
Had this in the stash for a long time, maybe I should have left it in there. Needs more work that I was willing to put into it, and the decals for around the nose finally convinced me to Whiff it instead of going Real World. Had some old Swedish decals in the stash, so the Svenska marinen got one, just to be bigger than the de Havilland Dove that the real world Svenska flygvapnet bought in 1947. Decals went on ok, but one fuselage roundel shattered as it was applied, so I didn't try any others after that in case it turned into a disaster and my language turned the air blue. If you decide to build one, the amount of nose weight required could bankrupt you and/or damage your storage shelf. You have been warned.
TomZ
Looks very good. Especially considering the quality of the original kit.
TomZ
loupgarou
Quote from: TomZ on April 05, 2024, 11:51:06 AMLooks very good. Especially considering the quality of the original kit.
TomZ
Indeed!
It's the ancient Airfix one?
Quote from: loupgarou on April 05, 2024, 03:05:02 PM
TomZ
Indeed!
It is, and the molds are definitely showing their age.
Very smart - and I don't think I've seen a whiffed dH Heron before (tbh you don't see many built RW examples, either).
Very nice, an aircraft I am quite fond of too. So much so, I put 4 turbo props on one and gave it a job wit RAF middle east command.  :wacko:
That's nice! Very subtle and elegant, I like it a lot.  :thumbsup:
Quote from: kitbasher on April 05, 2024, 11:51:12 PMVery smart - and I don't think I've seen a whiffed dH Heron before (tbh you don't see many built RW examples, either).
The Royal Flight flew Herons when I lived at Benson in the 50s. Bright RED ones at one stage too!  :o
Quote from: The Rat on April 05, 2024, 10:49:35 AM...the amount of nose weight required could bankrupt you and/or damage your storage shelf. You have been warned...
They would tail-sit IRL if the rear passengers were boarded first.
I have two in the stash*.  ;)
The nacelles are very narrow (Gypsy Major in line engines) making re-engineing tricky.
*Just had a thought.  DH Albatross California Condor.  Longer fuselage, Eight engines.  Very very long wings...
Quote from: zenrat on April 06, 2024, 04:48:04 AMThe nacelles are very narrow (Gypsy Major in line engines) making re-engineing tricky.
Garrett turbo-props from the Airfix Jetstream? You  might only need two of them, but then it'd look like  stretched Dove.
As for the Cali Condor, BRING IT ON!   :thumbsup:
Quote from: PR19_Kit on April 06, 2024, 06:45:29 AM
Quote from: zenrat on April 06, 2024, 04:48:04 AM*Just had a thought.  DH Albatross California Condor.  Longer fuselage, Eight engines.  Very very long wings...
As I said, I have two Herons.  One old, one new.  Now, just thinking out loud here but if I cut the outboard sections off one set of wings and then split what's left lengthwise I can match up the leading edges and the trailing edges and plate the gap to give me longer wings with greater chord at the roots but the same proportions as the originals (just longer).  I would then be able to use the new chord dimension as a measurement for where to cut the fuselages to extend the length with what would in effect be a plug over the wing roots.  A second plug ahead of the leading edge might also be required to restore visual balance.  Also longer stabilisers and maybe a taller fin.
Yes, yes, YES, YES, YESSSSSSSSSSSSSSSSSSSSSSSsssssssssssssssssssssss!
Quote from: PR19_Kit on April 07, 2024, 05:46:21 AMYes, yes, YES, YES, YESSSSSSSSSSSSSSSSSSSSSSSsssssssssssssssssssssss!
So, you like long wings, duz ya?  ;D
Heres my "ample"powered version. :wacko:
