Tempest for two
Started by The Wooksta!, March 30, 2024, 05:32:59 AM
Started ages ago, abandoned for years after painting, finally finished a while back (2022).
I don't like it. Something went wrong with the varnish.
Yep, looks like something went very wrong with the finish. :o
I feel your pain.
It looks similar to what happened to the Seahog.
What a shame, it's a great concept - a real double-taker, there'll be many who will think they've seen a two-seat Sea Fury and then on closer inspection realise they've been had.
Ever thought about stripping an repainting it ?
Yes, as soon as I ca get something that cuts through acrylic.
perttime
Looks OK in some of the photos. "A bit rough" in others.
I see what you mean.  Could you weather it up, a beaten airframe prior to restoration?
Quote from: The Wooksta! on March 30, 2024, 12:40:20 PMYes, as soon as I ca get something that cuts through acrylic.
Simple Green should do that, it's worked on some of mine.
Is it available in the UK?
I have a recommended Mr Hobby product on order to strip something else, so I'll give it a spin here.
perttime
At least Simple Green has a UK website https://www.simplegreen.co.uk/ No idea about retailers. Hardware stores?
Simple green has multiple products. Are people referring to the "Original"?
Quote from: The Wooksta! on March 31, 2024, 01:31:40 AMIs it available in the UK?
I Googled for "simple green uk" and it would seem that it is. However I learned that it will not remove Tamiya Fine White primer from a rattle-can, in fact it seems to toughen it!  ;D
