avatar_chrisonord
Parts bin armour.
Started by chrisonord, November 15, 2023, 01:47:39 AM
A while ago I bought a part built Airfix Centurion kit from someone on here, which unfortunately had a few important bits missing. Fast forward to about a week ago, when putting all my kits away ready for moving, and  I put said centurion on the work station, and started to rebuild it, and mess around with some paint on it. But I still needed turret parts and a gun, so I had a dig through the parts bin and found an AMX 30 turret, mantlet and gun, stuck them on and they look ok to me. I might change the gun for something withna bit more detail, and I need to find the rest of the AMX turret parts tòo. I have some white metal LMG's like the ones I put on my RAF regiment Staghounds, so one of those can go on top of the commanders cuppola.
Here's what I have done with this so far, I think I have stuck enough bits to it now. Ti me it looks right, so that will do for me, I stuck a spare centurion barrel on it too wich looks ok, and a ser of centuriin smoke dischargers. Next job is to make one M 60 out of the scrap parts of several I have salvaged. :wacko:
Isreali?  They'd be most likely to do this sort of mix and match.
Quote from: The Wooksta! on November 24, 2023, 01:30:12 PMIsreali?  They'd be most likely to do this sort of mix and match.
This one is going to be protecting a Uranium mine in Africa. Made from parts of damaged or dead armour hit lots with hammers and cutting gear to make it fit together. I have a chafee tank awaiting a similar fate, it will get a Rarden 30 mm cannon fitted to it and a roof mounted LMG.
Chris that's cool mate ..the turret looks just right with the 20pdr gun . AMX30 turret is it ?
Quote from: Wardukw on November 24, 2023, 05:58:24 PMChris that's cool mate ..the turret looks just right with the 20pdr gun . AMX30 turret is it ?
Yes, its from the Heller 1/72nd scale kit, the hull is 1/76th airfix centurion, and the gun is a spare from the Vespid Mk5 centurion. I tjought I had all the turret parts but I must have used them all when I built the ARV version. It's the one at the rear right in this picture.
Quote from: chrisonord on November 25, 2023, 01:37:23 AM
I do like tanks with long gun barrels Chris and that 20pdr looks just right..the AMX30 already has a long gun so the balance is just bang on  :thumbsup:
Slap that on a sizable chassis and bingo  ;D
Here is the finished tank, named Centeur, as its part French, the tank performed spot on after a few other upgrades too, and the turret and gun worked as anticipated.
Hmm, not as well detailed as the M-60 or the Chieftain but good enough, & a good combination of hull, turret & gun. :thumbsup:
Quote from: Old Wombat on December 02, 2023, 04:06:38 AMHmm, not as well detailed as the M-60 or the Chieftain but good enough, & a good combination of hull, turret & gun. :thumbsup:
The centurion bit is the old airfix kit, and pretty well lacking on the detail front, and I am a bit sparse in suitable add on bits to suit a tank of the time period. The turret is the old Heller AMX 30 one, and is alsk quite lacking in any detail.
 :thumbsup:  :thumbsup:  :thumbsup:
Sometimes simple can be very affective in getting great results  ;D
