L/F Mistercraft Siegel Si 204A civil markings
Started by The Wooksta!, June 21, 2023, 07:00:11 AM
What it says on the tin.  Wanting the Spanish civilian option to apply them to a later D model.
You can't get the kit in the UK and I'm not prepared to pay the huge asking price of 15 quid plus another fiver postage when I can get the SMER boxing in the UK (if I want another 204A) for far less than a tenner.  I have a few of the original base kit tucked away. Just the Spanish decals I'm after.
If you're not in a hurry perhaps I could print a decal set for you? I won't be near a printer till the 27th though.
Is there even a vague image of the sheet you're looking for anywhere?
Found this one, but I think the resolution will be too low - 72dpi is fine for monitors but try printing it and you get bitmapped mush.  Needs to be a minimum of 200dpi.
TBH, it's really a long shot, as I don't do civilian aircraft as I prefer military, finding Spain had actually had the type was actually more important.
That's fine Lee, I can work with that.
What's the correct size, in mm, for one of those roundels, or the big reggies, and then  I can scale the artwork correctly?
I've nearly done the WHOLE sheet, French and German markings as well, and then I remembered you only wanted the Spanish ones, which are the simplest of course.  :banghead:  :banghead:
I'll be home tomorrow and can print them out.
I'll come back on the size of the tail fin tomorrow.
I think I've got it anyway, I have some 1/72 scale plans and scaled it off that, but it'd be good with your confirmation as well.
The measurements of the kit fin and the plans are quite likely to vary somewhat!
