Main Menu
avatar_Ed S
I'm Back
Started by Ed S, June 09, 2023, 07:49:00 PM
Ed S
Yep. Still around.  We're still traveling a lot in our RV, but this week we are at home base.  So I'm going to join the group build.  Of course, we are leaving town next Sunday morning, so I have already cut myself one day short.  I'm going to build a Hasegawa Mig 27 1/72 scale.  I'm still thinking about colors, camo, markings, and back story.
Obligatory photo of parts.You cannot view this attachment.
frank2056
Good to see you back, Ed. That's a nice kit for its age.
AeroplaneDriver
Perfect timing!  Good to see you back Ed!!
Great to see you Ed  :thumbsup:
Ed is back.   :thumbsup:
I've built the MiG 23 version of that kit.  Can't remember anything which will stop you finishing it in a week.  It has the usual need for PSR around the intakes.
Ed S
Thanks for the welcomes.
Quote from: zenrat on June 10, 2023, 05:54:32 AMEd is back.   :thumbsup:
I built both versions back in the 70-80's.  Some of Hasegawa's better work at the time.  Should be good 1 week subject.
Ed S
Today's progress.  The fuselage top and bottom are glued up and the new wings installed.  Putty applied to fair the new wings into the existing fuselage.
Also got the cockpit interior primed and painted in the odd blue-green Russian cockpit color.You cannot view this attachment.
Welcome back Santa!
Good to have you back, Ed!
Ooooh, none of those silly swinging wings then?  :o
Ed S
Day 2
ARGGGGGHH!!!!  Just figured out today that I am missing an entire sprue of parts.  Some of which I need.  Yes, I could scratchbuild replacements or scrounge around the internet and find a cheap kit.  But not in the short time frame.
So Plan B.  I have an old AHM F-104 Starfighter 1/72 ( or there abouts).  Not a great kit, but it does look like an F-104 and did I say OLD.  I think I might have built this kit back in the 60's as a kid.
Ed S
PS  Yes, good call.  The Mig is being built with a fixed wing not a swing wing.  I was intending for a strike plane similar in configuration and mission to the Jaguar.  I hope to get back to it in the future.
Quote from: Ed S on June 11, 2023, 08:40:05 PMPS  Yes, good call.  The Mig is being built with a fixed wing not a swing wing.  I was intending for a strike plane similar in configuration and mission to the Jaguar...
Ah, like this.
Mirage F.1 or F-16 wings might work well on the MiG-23/27 airframe?
Ed S
Day 3     Model #2
Got the basic assembly  done today.  Which for this kit is really simple.  Just glue the fuselage top & bottom together.  Cut off the original wings.  Add new larger intakes for the larger engine.  Fill in around the new intakes to blend to the fuselage.  Using mostly small pieces of sheet styrene and CA glue.  Grind that to rough shape with Dremel.  Add new wings and fair into the fuselage.
The result
Spread on a thin coat of 3M acrylic filler.  (blue)  This will fill in all the small imperfections and make a nice smooth finished surface.  A quick sand tomorrow after it cures overnight and get a primer coat tomorrow.
