Main Menu
avatar_NARSES2
General Discussion
Started by NARSES2, June 02, 2023, 06:46:26 AM
This is for any general discussion on the GB
Think I may be in with a Sabre Beaufighter.  Think I'll have to do a bit of casting first.
I'm gonna be in with a Griffon powered Grumman Tigercat and it will be a RN bird.
A failed project of mine was to re-engine the Lockheed Constellation with four Alison T-56 turboprops. A lot of PSR is needed to plug the wings. The Rolls-Royce Griffon engines fit most of the radial aircraft, I have had problems fitting them on the 1/72 Heller Douglas DC-6B,although I fancy a DC-3 this time.
Trying to think of something to stick a Centaurus on the front of ?
Swap-out the R-3350 of an AD-5/A-1E?
Add skis and paint it orange for the BAS?
Quote from: NARSES2 on June 03, 2023, 06:03:19 AMTrying to think of something to stick a Centaurus on the front of ?
A Meteor?  ;)
#7
Been carefully hoarding a kit (well, most of it, the lower hull and running gear were used elsewhere on an ARV Conversion and will have to be sourced) for this type of GB.
Gas Turbine Chieftain is the plan.
There was work done in the UK on this concept and a powerplant prototype based on a Conquerer, but nothing production for the Chieftain as far as I can find out
Now unlike the generally blatantly obvious engine changes on an Aircraft, this will not be very obvious, so it will depend on the moderators to let it go ahead or not
With a major Model show coming up hopefully I can a find suitable lower hull and running gear replacement.. or just another Tamiya Chieftain, as they are on the whole quite cheap.
Had a similar idea awhile ago with a Challenger 2 by using a Abrams turbine .
As like alot of ideas it got put by the way side.
Convert an Abrams to diesel power. Needs to be done RW.
Quote from: kerick on June 03, 2023, 11:19:32 PMConvert an Abrams to diesel power. Needs to be done RW.
Why?
Quote from: jcf on June 03, 2023, 08:55:24 AMSwap-out the R-3350 of an AD-5/A-1E?
Heh - get out of my head... ;D
I was just looking on the side of the box that my Tigercat is packed in and it's got this little section about the stats of the plane .
Well reading that info panel I came across something quite funny.
According to the info the twin engined F7 Tigercat is powered by a single Allison V1710 in line engine..
Could that be anymore wrong and yet there is and it was never picked up on ..amazing  ;D
Quote from: jcf on June 04, 2023, 12:18:15 AM
Why?
Improve the range, increase the fuel capacity, so on...  :thumbsup:
Quote from: rickshaw on June 04, 2023, 02:39:01 AM
Why?
Bring the thermals of the turbines heat down too.
