avatar_buzzbomb
2001 Moonbus in 1/144
Started by buzzbomb, April 28, 2023, 04:59:53 PM
As some of you have seen, I have quite a few of the Stargazer Models 1/144 2001 Vehicles. Ian (Stargazer) is good pal, I have know for quite a number of years and he has produced some cracker kits.
The range of 2001 kits is produced to a constant 1/144 scale, so I have the Discovery, Aries and Orion.
More info on these  here
The latest I am doing form the Stargazer Models stable (the real Stargazer Models of Devon as apparently there is another business of the same name getting around) is the 1/144 Moonbus
So compared to the Moebius or old Aurora offering, this is tiny
Part breakdown, courtesy of the Stargazer Website as I forgot to take a picture
I jumped straight in. As with all my 2001 models, it had to have lights. Being very small about 7cm long, space is a challenge
For the blue roof lights, some SMD Led on copper strip, a red cockpit LED and two headlights
Getting power in is the next challenge. So the path I took was to run it down as part of the landing gear, so it is mostly hidden, then some pre-painting of the interior
It works  8)
More shortly. Thanks for dropping by
Brian T
Steel Penguin
tiny perhaps,  but perfectly formed  :thumbsup:
and word play aside, that is look well smart so far  :thumbsup:  :thumbsup:
Vulcan7
This is going to look the business  :tornado:  :mellow:  :thumbsup:
#10
A few recent distractions, but back to the bench on this Moonbus.
Added a couple of internal figures, we are working in 1/144. The standing one being a 3D print and the pilot some weird Airfix pilot figure from the spares box that was a lot smaller than the normal 1/72 for some reason, but in the standard 60's style pose.
To be clear,  this is not a commercial casting, this was a bunch of reject bits that Ian at Stargazer put together for me as a favour, to add to my collection of his kits.
So next was to bang it all together and a primer coat, which highlighted the expected bubbles in the casting.
All the wiring was routed under the ship and right next to the landing skids. So when it is on the base, it will hardly be visible.
Again more bubbles, but current working through as many of these as I can and a bit of sharpening  up some of the panels, as far as practical
Very very nice 👌 👍 😊
I've met you Brian and I can't remember you having the micro fingers required to produce work like this in such a small scale.
You are doing good.  Carry on.
What did they use for casting resin? Some sort of foam?
Great work here!
