avatar_Gondor
Meteor PR.10
Started by Gondor, March 05, 2023, 07:37:19 AM
I decided to add this build to the other ideas I have had.
First off a pictures of what will maily be used in this build.
Box and bag of parts
Sprues and parts of the Matchbox kit. Some parts are loose because I removed unnecessary parts as it was going to be an NF.12 many years ago, now Special Hobby do that kit so using this for the Group build is not a problem.
The conversion set
The conversion should be straightforward as the Aeroclub set was designed for the kit. Not much will be seen inside the cockpit and it was painted black in there, cue the Rolling Stones.....
Decals will be found or sourced later as they should be around here somewhere....... if not there is plenty of time to get other ones from the Airfix Spitfire PR.XIX.
Remember some transverse  bulkheads. They'll hold the fuselage steady when trying to eliminate the join line of the top piece.
Great idea Lee. Only ever had the bits to build these and never got around to doing so. I am using one of the Meteor cockpits you gave me in this as it gives the nose wheel bay some depth and detail as well as something for the inside of the cockpit.
Quote from: Gondor on March 05, 2023, 11:07:44 AM
Quote from: kitbasher on March 05, 2023, 10:47:34 AMSwedish, perhaps?
Yup  :thumbsup:
Nice
Quote from: The Wooksta! on March 05, 2023, 12:46:38 PMRemember some transverse  bulkheads. They'll hold the fuselage steady when trying to eliminate the join line of the top piece.
And to lengthen the cockpit 'hole' in the replacement fuselage decking, it's a shade too short - pilots would otherwise definitely lose their knees when ejecting!
Quote from: kitbasher on March 05, 2023, 02:31:37 PM
Yup  :thumbsup:
Nice
I will use the new Airfix kit as a guide for the hole then.
Forgot to say yesterday, a blood sacrifice has been given to the modelling gods as I was stupid and attempted to make a cut while holding things the wrong way around. My blade slipped and I had a cut on the top of my little finger which bled a little. No real problem, just a slightly awkward place for a cut.
Quote from: Gondor on March 05, 2023, 10:26:40 PM
Yup  :thumbsup:
Nice
Speaking as a person whos covered in cuts and stitches...Al is there any place where a cut is good ?  :lol:  ;D
Quote from: Wardukw-NZ on March 05, 2023, 11:28:54 PMSpeaking as a person whos covered in cuts and stitches...Al is there any place where a cut is good ?  :lol:  ;D
Yes, between the Sprue/Runner and the part you need  ;D
Quote from: Gondor on March 06, 2023, 01:50:37 AM
Hahaha yup I'll go with that  :thumbsup:
Proof of progress
I know it dosent look like much, and truthfully the picture doesn't show much, but it is progress.
Something is better than nothing Alistair and do love a good Meteor matey  ;D
There was concern about the cockpit opening with the Aeroclub conversion set so I dug out one of the part built MPM/Special Hobby et al Meteor F.8's I started last year as a comparison.
There are differences between the two with the Aeroclub decking being a bit more indistinct than I would have liked, but there is the basis for a reasonable cockpit opening to be made.
To be fair to John Adams, the conversion is a limited run circa 1987. It's vastly superior to some resin ones released more recently.
Quote from: The Wooksta! on March 17, 2023, 12:51:14 PMTo be fair to John Adams, the conversion is a limited run circa 1987. It's vastly superior to some resin ones released more recently.
I agree. A Garage kit against a short run kit and it is close. As you say Lee, vastly superior to some resin stuff that you keep going on about  :rolleyes:
