avatar_The Rat
AK True Metal paste, success at last?
Started by The Rat, January 30, 2023, 09:41:19 AM
Some of you may recall me saying that I was having some trouble with this stuff. Might have figured it out, at least partly. On previous models I was applying it gently with a cotton swab, and buffing it the same way. Not the way to go, it seems.
From a long unseen drawer came a partially completed DH Airfix Comet, warts anbd everything, and I decided to get cracking on a RW build. Black on the undersides as a base, and then the AK paste over top, and buffed with a good amount of pressure using a 'shop towel', not sure if that description is the same in other countries. Basically a very strong paper towel, usually coloured a medium blue, for strong jobs and industrial type cleaning. And it buffs up very nicely that way, leaving a sheen that doesn't seem to be rubbing off on my fingers.
Quote from: The Rat on January 30, 2023, 09:41:19 AMbuffed with a good amount of pressure using a 'shop towel', not sure if that description is the same in other countries. Basically a very strong paper towel, usually coloured a medium blue, for strong jobs and industrial type cleaning. And it buffs up very nicely that way, leaving a sheen that doesn't seem to be rubbing off on my fingers.
Used to call that Elephant Bog Paper when I was in the RAF because of the size of the roll  :rolleyes:
Beermonster58
I agree about the nice finish you can get with this material but, it certainly doesn't like being masked over which, is a problem if wanting a multi toned finish.. It's not very durable .
Basically the same as Rub 'N Buff, which is powdered metal carried in a soft wax.
It's a very old type of finishing compound, gilding wax, despite Amaco claiming that
Rub 'N Buff, which they introduced in the 1960s, is the "original".
Quote from: jcf on February 01, 2023, 12:26:13 PMBasically the same as Rub 'N Buff, which is powdered metal carried in a soft wax.
Rub 'n Buff seems to work better, but can't get it in Canada now.
Quote from: jcf on February 15, 2023, 02:05:13 PMAmazon Canada shows it available
Okay, thanks, but I refuse to deal with Amazon, so that's probably why I disregarded it in web searches. Might try to pick some up if I nip across the border, it's only a couple of hours away.
Quote from: The Rat on February 15, 2023, 05:23:02 PM
Glad i'm not the only one.  Keep up the good fight brother.
Quote from: zenrat on February 16, 2023, 03:05:02 AM
Leading Observer
I wouldn't recommend typing Rub n' buff into a search engine... :wacko:
LO
