avatar_Firefox
F-15 Sprint Eagle
Started by Firefox, January 01, 2023, 11:03:15 PM
Firefox
I must admit I did not intend to make this a what-if models. But if you have made a Hasegawa 1/72 F-15 that came out around 90's, you'd probably know that it's a little bit over engineered, especially the exhaust nozzles. Despite my  best efforts, the nozzles did not come out round (one nozzle is made out off five parts that you can barely glued together, let alone making it round, at least not with my skill  ;D ). Needless to say, I consigned them to bin after a few tries. And I have a few extra F-16 nozzles sitting there, but the diameter of the nozzles are much bigger that the F-15. Hence, the beginning of this whiffy: What it F-15 is using two F-16 engines?
Completed model is on page 2
The first few steps is to 'enlarge' the engine bay areas
Applied some miliput and quite some sanding:
AeroplaneDriver
#1
Not to denigrate your build in any way, because it is looking great...but the F-15 DOES have 2x F-16 engines. They both use the P&W F100-200 series. Different kits with varying accuracy would be my guess for the discrepancy.
But never mind,  great looking conversion no matter what the engine is!!!   :thumbsup:
That's subtle and looks very cool!  :thumbsup:  IMHO the model could have deserved thinner/more strongly swept wings witn this upgrade?
Quote from: AeroplaneDriver on January 01, 2023, 11:54:03 PMNot to denigrate your build in any way, because it is looking great...but the F-15 DOES have 2x F-16 engines. They both use the P&W F100-200 series. Different kits with varying accuracy would be my guess for the discrepancy.
He's right, you know! ;)
Still, this should be fun! :thumbsup:
Firefox
Thanks for pointing this out  ;D  I didn't know they are the same. Good to know. The larger diameter of the F-16 nozzle is probably because of the requirement of the aerodynamic design then.
Firefox
Quote from: Dizzyfugu on January 02, 2023, 12:12:52 AMThat's subtle and looks very cool!  :thumbsup:  IMHO the model could have deserved thinner/more strongly swept wings witn this upgrade?
If I intended to build it as what-if, I'd probably go down that path you said. I came across F-15U over the internet, it seems like having the swept wing you mentioned.
You can always add a pair of canards and turn it into a STOL version.
This will be the 1988 new mould.  It looks to be an improvement over the '74 mould.
I looked up 1/72 Hasegawa F-15 Eagle on Scalemates.  I can't believe how many different releases there are.
Firefox
#8
Quote from: McColm on January 02, 2023, 02:05:24 AMYou can always add a pair of canards and turn it into a STOL version.
I've done that a while ago  ;)
I'd probably stick to the minimum with this one since it began as a real world build.
Firefox
Quote from: zenrat on January 02, 2023, 03:01:43 AMThis will be the 1988 new mould.  It looks to be an improvement over the '74 mould.
Yes, there are so many releases even with the new mold  :o One of the more if not the most memorable is the F-15 SMTD. Couldn't believe Hasegawa actually made one.
If you are using the Hasegawa F-16 nozzles they are oversize. They are too big for an F-14D also.
But now that you are putting in much larger engines on your F-15 will you be enlarging the intakes for all that increased air flow?
I know, I'm not helping....... ;D
But the swept wings sound cool.
What about a pair of F-14 wings instead?
This works right rather well ..take a big arse figther and fit even bigger engines and that's a recipe for good times 👹😁
Quote from: Firefox on January 02, 2023, 01:58:52 AM
Depends on the F-16 kit.  Later Falcons (not all of them) use the GE F-110, had about 4000lb more thrust. Might be useful for your build.
Firefox
Quote from: Wardukw-NZ on January 02, 2023, 11:05:21 AMThis works right rather well ..take a big arse figther and fit even bigger engines and that's a recipe for good times 👹😁
that's the idea  :wacko:
