Author Topic: Reverse engineered F-16  (Read 751 times)
Offline Geoff
  • Knows a probation officer in Hull
  • What-IF SIG
« on: June 02, 2021, 04:01:28 pm »
OK a bit simplistic PRC obtain an F-16 and reverse engineer it for a Spey with the large intake as the J-? Just a thought. :o
Offline Gondor
  • What-IF SIG
Re: Reverse engineered F-16
« Reply #1 on: June 03, 2021, 02:31:18 pm »
Well it would make sence to enlarge it a bit as Japan did with it's F-2 or you could do similar things as I have done in the past such as F-2-16C or even this Lockheed-Mitsubishi F-16J-2A 3rd SQ, 3rd AW, JASDF TAC MEET Misawa AB 2010
Offline Nick
  • What-IF SIG
« Reply #2 on: June 03, 2021, 02:34:08 pm »
Sounds like what the Japanese did with their F-16s to get the Mitsubishi F-2 but at huge cost.
https://en.wikipedia.org/wiki/Mitsubishi_F-2
Offline McColm
« Reply #3 on: June 14, 2021, 04:21:51 pm »
The Japanese also back engineered the F-18 Hornet as well.
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #4 on: June 15, 2021, 03:37:34 am »
They did? And did what with it?
Offline rickshaw
« Reply #5 on: June 15, 2021, 05:41:48 am »
I think you're referring to the Chung Kua the Taiwanese indigenous fighter but that is basically a twin engined F-16.
Offline McColm
« Reply #6 on: June 15, 2021, 01:53:37 pm »
They used it as a stealth demonstrator and then put it in a museum.
Offline Geoff
  • What-IF SIG
« Reply #7 on: June 16, 2021, 08:28:58 am »
Equipped 4 carrier air wings as well. Had really nice commemorative schemes in the 1990s
Offline Knightflyer
« Reply #8 on: June 16, 2021, 08:56:38 am »
Do you mean the Mitsubishi X-2 Shinshin ?
Oh to be whiffing again :-(
Offline Snowtrooper
« Reply #9 on: June 16, 2021, 11:56:18 am »
What. This is the first time I ever hear of X-2 being a "reverse engineered F-18", plus it did not even exist in the 1990s so it could hardly equip carrier air wings which Japan didn't have either at the time (in the present they're building their totally-not-carrier air wings around F-35B).
F-2 did/does equip four land-based wings, but only if you count the test wing and training wing as well. Also, F-2 being "reverse engineered" is a stretch as GD shared the technology and blueprints (largely already based on their ATF concepts) and participated in the development.
What I thought the original post was about that the Chinese would more or less on their own reverse engineer a F-16 and install a licence-built Spey and domestic avionics (somewhat paralleling the J-11/Su-27, and even that started as a coproduction).
Offline Knightflyer
« Reply #10 on: June 16, 2021, 12:10:47 pm »
I was trying to find out which aircraft McColm was referring to? I'm now thinking the first flight was on the day after the last day of March? :o :-\
Offline Geoff
  • What-IF SIG
« Reply #11 on: June 16, 2021, 02:35:52 pm »
ah sorry I'll get me coat
Offline McColm
« Reply #12 on: June 16, 2021, 03:19:07 pm »
X-2 based around the F-18 with stealth features from the F-22, first unofficial flight 2018 from a source who says that they 'cannot deny or confirm that the information is true ' unquote.
Offline Knightflyer
« Reply #13 on: June 17, 2021, 03:06:17 am »
The X-2 made its maiden flight on 22 April 2016 taking off from Nagoya Airfield and landing at the JASDF's Gifu Air Field after a 26-minute flight....... unless Wikipedia is really REALLY wrong?
Offline McColm
« Reply #14 on: June 17, 2021, 05:34:36 am »
Must be my medication kicking in again  :banghead:
