Author Topic: Fixing Transparencies ?  (Read 808 times)
Offline NARSES2
  • Global Moderator
« on: December 11, 2020, 06:19:18 am »
For years now I've used Humbrol Clearfix to fix my transparencies to the fuselage etc. Anyway it has it's uses (it will fill small gaps etc) but can be a tad messy given its inherent "gloopiness".
So as I'm coming near to the end of my current jar I was wondering what others use to fix their canopies in place ?
Decals my @r$e!
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
Re: Fixing Transparencies ?
« Reply #1 on: December 11, 2020, 06:24:31 am »
I've used 'Gator's Grip Acrylic Hobby Glue' for ages. Sticks canopies AND fills in windows too, just like Kristal Klear.
I'm still on my first bottle too..................
Offline Steel Penguin
  • What-IF SIG
« Reply #2 on: December 11, 2020, 09:58:30 am »
bog standard, generic PVA for myself.
Redone 19/08/15  the things you learn, give your mind the wings to fly, and the chains to hold yourself steady added 07/10/18   take off and nuke the site form orbit, nope, time for the real thing, CAM and gridfire, call special circumstances.   wow, its like freefalling into the Geofront
Offline rickshaw
« Reply #3 on: December 11, 2020, 12:13:33 pm »
I use "Watchmaker's Glue".  Get it from Evilbay, usually from the US.  I have been using one tube for about 18 months and have a spare.  Fairly cheap.  It is a clear glue.  Sticks like all buggery but won't fill gaps.
Offline joncarrfarrelly
  • Bertie Bassett
  • What-IF SIG
  • Turn that Gila-copter down!
« Reply #4 on: December 11, 2020, 05:08:19 pm »
This is what Brian is referencing. It's also one of my preferred clear bits adhesives.
https://www.amazon.co.uk/Jeweltool-Hypo-Cement-Twin-Pack-dp-B00PKGSBKA/dp/B00PKGSBKA/ref=dp_ob_title_kitchen
“Conspiracy theory’s got to be simple.
Sense doesn’t come into it. People are
more scared of how complicated crap
actually is than they ever are about
whatever’s supposed to be behind the
conspiracy.”
-The Peripheral, William Gibson 2014
Offline rickshaw
« Reply #5 on: December 11, 2020, 07:57:08 pm »
That's the stuff.  Stick like all buggery after a while and is dead clear.  No good for filling gaps though.   :angry:
Offline Dizzyfugu
« Reply #6 on: December 12, 2020, 01:03:30 am »
I generally use simple white casein glue, because it is water-based and, once dry, becomes almost transparent. Slightly thinned the stuff can also be used to fill small gaps.
Never heard of the watchmaker glue, but it sounds interesting.  :thumbsup:
Offline zenrat
« Reply #7 on: December 12, 2020, 01:15:46 am »
Krystal Klear.  Sticks as well as it needs to but can generally be make to let go when I realise I knocked the canopy and misaligned it before the stuff had set.
KK seems to grip better than ordinary builders PVA.  I've also tried wood glue.  Had no discernible difference to ordinary PVA.
If I need more strength but still require clarity I use 5 minute epoxy.
If I am going windows into a fuselage and there is a risk I may push them inside once the halves are closed I (very carefully) use Tamiya Extra Thin.
Offline chrisonord
  • DIDN'T READ THE QUESTION PROPERLY
  • Paint it gloss??......HOW DARE YOU!!!
« Reply #8 on: December 12, 2020, 07:34:45 am »
Whereabouts did you buy this stuff from please Kit??
Offline PR19_Kit
  • What-IF SIG
« Reply #9 on: December 12, 2020, 09:37:42 am »
From my local art shop in Chepstow. Sadly they closed 4-5 yrs ago, but it seems it's quite common in the art field.
Offline chrisonord
« Reply #10 on: December 12, 2020, 03:24:26 pm »
Thankyou  Kit, I had a look for it ont tinterweb but nothing  come up. I will  see if I can get it locally somewhere.
Cheers
Offline NARSES2
  • Global Moderator
« Reply #11 on: December 13, 2020, 05:51:26 am »
Cheers for these tips lads  :thumbsup:
Decals my @r$e!
