In service TSR 2
Started by Devilfish, July 23, 2020, 10:58:29 PM
Devilfish
Had the TSR 2 not been cancelled in 1965, there were several changes that needed to be made to it, before it entered service. These are all documented changes, and i have tried to incorporate them into this kit to make it as "in service" accurate as I can
Starting from the front, these are the mods I have done to the kit
The pitot was to have a "bulb" on it much like the later Jaguar.  To that end I have fitted a brass Jaguar item.
A retractable bolt on refuelling probe was to be fitted to the left hand side (scratch built)
The optics of the canopies was not good enough, but no development was done on this, so I have just removed the gold tint, which was a heating element.
The instrument panels were scratch built to make them more accurate, and a HUD was fitted.  The original plan was for a HUD projecting on the front screen, but they couldn't get that to work, so an American system was to be fitted.
I have fitted resin insides to the canopies
The 3 strike camera positions were opened up and glazed.
The extendable nose leg was found to be unnecessary, so was to be deleted. I removed the extra link from the leg.
Metal undercarriage was fitted
The forward fuselage to wing "hump" was reduced and the extra vents added (restored?)
The intake aux air doors weren't good enough, so a new method was devised, where the whole front edge slid forward to allow more air in.  Intakes modified to match drawings.
The long range fuel tank was scratch built from 2 off a Boston bomber
Master Caster Blue Water missiles fitted to modified F-15 pylons
Outer pylons made from modified and inverted F-35 pylons, with home made "rapid blooming windows" pods
Brake likes were added to the main legs.
The wing tip fuel dumps were thinned down as they were way too thick.
The airbrakes were to be vented, like those on the Jaguar. The kit items were drilled out
The screw jacks, used to open the airbrakes was to be replaced with a "normal" hydraulic system.  Lower airbrakes drooped to represent this system at rest.
A one shot arrestor hook was to be added. One found in the spares.
Under fuselage strakes were talked about to help stability.  Modified F-8 strakes fitted
The kit's upper fuselage vents were replaced with resin items.
An intake was added to the fin.
P/E access ladders fitted (modified to a simpler design, for in service use)
Enough reading...on with the photos.
DSC_0240 by Paul Carter, on Flickr
DSC_0245 by Paul Carter, on Flickr
DSC_0259 by Paul Carter, on Flickr
DSC_0256 by Paul Carter, on Flickr
DSC_0255 by Paul Carter, on Flickr
DSC_0243 by Paul Carter, on Flickr
DSC_0242 by Paul Carter, on Flickr
DSC_0251 by Paul Carter, on Flickr
DSC_0250 by Paul Carter, on Flickr
That looks great, and your list of mods will be a handy reference  :thumbsup:
Cobra
Superb Build :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: why do i picture a Scramble Klaxxon going off & a Controller Calling out,"All Crew man Your Planes,Scramble,Scramble!!"? Keep up the Superb Work :cheers: :cheers: :cheers: :cheers: Dan
Is that the 1/48 scale kit?
Nicely finished by the way  :thumbsup:
Marvellous stuff  :thumbsup:
That's a tremendous piece of work  :thumbsup:
I have no idea if the TSR 2 would have been as good as its proponents state, if it had entered service, but it really is a nice looking aircraft! :thumbsup:
What are the large missiles on it please?
TomZ
Glenn Gilbertson
Excellent work - & thanks for the details. :thumbsup:
Quote from: chrisonord on July 24, 2020, 09:27:29 AM
Those are Blue Water. A tactical nuclear air-to-ground missile. Proposed range was about 60 miles/100 km. A ground-launched version was also envisioned. Neither got off the drawing board.
Cheers  Hobbes, they look like  something that would be  good  on one or two of my builds, perhaps mounted on  phantom  or Canberra.  Are they scratch built?
