avatar_Tophe
BAé Arrière (finished page 2)
Started by Tophe, February 08, 2020, 09:26:10 AM
- I have ordered and now received a very cheap BAe Harrier GR7 1/144 Revell.
- My plan is to discard the tail (the tailplanes becoming canard foreplanes and the fin being moved forward), have a low wing, no jet exhaust and maybe no air intake, depending on the plastic aspect there.
- I imagine it is to export to France as Britiche Aérospass Arrière 7 (pronounced by French people as they pronounce British Aerospace Harrier 7). And « les Arrières » (to protect) means the Rear (of the army).
That sounds very wierd, but then, where it is coming from, perfectly normal.
Looking forward to the photos.
Thanks!
Quote from: JayBee on February 08, 2020, 11:08:43 AM
The first pictures are not the what-if transformation yet but the kit content:
Quote from: Tophe on February 08, 2020, 09:26:10 AM
Ahem, there is no plastic inside the air intake, so I must let it there, otherwise that would require tons of putty...
When it's built there's a big fan that fills up most of that space in the intake. I think it's the round bit in the top pic you've posted, just to the right of the fuselage half on the left of the sprue.
I've got a few of those kits too, so I'm familiar with the way they go together.
OK, so it will have air intakes, just the rest will be abnormal... :-\ :unsure: ;)
The first drops of glue seem to make a normal Harrier, then cutting the wings starts the transforming. I wait for the glue to dry before truncating the tail (and fin):
ericr
 :o :o :o
;D ;D ;D
The arrière is a perfect name  :thumbsup:
Thanks!
I have truncated the tail (then the fin) and included a jet exhaust from the spare box (and a drop tank 1/72 to decrease the amount of putty): <_<
First putty (to be completed, but too much at the same time would dissolve the plastic, I fear): :unsure:
Scotaidh
Now, that's a little five-engine hot-rod!   :thumbsup:
Thanks for the thumb up, while I am not sure it will have 5 engines at last: my project was to discard (cut away) the 4 lateral exhausts of the VTOL way (that is necessary I think to have a low wing below, changing completely the Harrier principle)...  :unsure: ;D
Quote from: Tophe on February 12, 2020, 02:47:34 AM
I have now cut away the lateral jet exhausts, easily (as Revell plastic is perfect for that, thanks to them), then I have filled the holes with putty (on one side as a beginning):
Then putty on the other side:
First sanding, then putty again: :-\
