P-47 wing swap
Started by Snowtrooper, January 24, 2020, 01:03:14 AM
Snowtrooper
I've had an idea of a project or two, which involves a swap of wings on a pair of P-47's. Specifically, swap P-47N wings to a Razorback P-47D. As this would leave me with a N fuse and D wings, well, something might come out of that too.
What 1/72 scale kits would allow me to get away with minimal surgery regarding the wing transplant? I guess for N the choice is Italeri (Heller with its mass of rivets might be a second option, but for a silly whiff butchering a Sword multimedia kit is a bit too radical), but which razorback D would it interface best with? There's at least the ancient Airfix, Frog, Hasegawa, and Matchbox offerings, and a "new-ish" tool from Academy (compared to the others, that is). Hobby Boss Easy Assembly would require major surgery as the wing and lower fuse are one piece. Scalemates lists Tamiya as a new kit even though I didn't know they had any "original" 72 scale models.
I have both Razorback and Bubble top Hasegawa Jugs (1974 moulds) in the stash.  I'll have a fiddle tomorrow and report back.
I must admit I wasn't aware they had different wings.
Snowtrooper
Quote from: zenrat on January 24, 2020, 01:52:30 AM
P-47D razorback and bubbletop have identical wings. P-47N had a different wing with integral fuel tanks and square wingtips (which were not simply cut off D wings).
Quote from: Snowtrooper on January 24, 2020, 02:12:27 AM
Ah, OK.   :banghead:  So not much point me fiddling with parts then,
You might also try not to simply switch the wings at their roots, but transplant the whole fuselage section, together with the wings. This might be easier (since the fuselage shapes should be very similar) than trying to mount wings on attachment points that were not designed to take the parts. I made a similar transplant a while ago when I mated the Heller N wings with the fuselage of an MPM J.
Snowtrooper
Quote from: Dizzyfugu on January 24, 2020, 02:36:55 AM
Thanks for the tip, might do this instead. That should make any Razorback (including the Hobby Boss one) eligible for the conversion :thumbsup: Should have thought of this in the first place since both ideas would require fuselage surgery anyway...
For those interested, the D with N wings would be a civilian passenger (!) conversion. The idea started forming when I was (again) wondering the sheer size of the Jug and started pondering just how much extra space there would be in the rear fuse if you removed the massive turbo and associated piping, and installed a R-2800 engine with a simple mechanical supercharger instead. The N wing transplant idea came to my mind when thinking of how to maximize the range. There would be a convoluted backstory only possible in the whiffverse on how and why the "Thunderbus" came to be.
For the leftovers, the plan would be to make a Reno Racer out of those, with surgery-extended cowling sufficient to fit Wasp Major in the backstory (in 3D form, I would simply hide the engine with a massive spinner to avoid using a resin part), larger air intake in the style of XP-47H (maybe having an underfuse "exhaust" for the radiators P-51 style too), severely chopped wings (I know, HERESY!), and any other suitable modifications to make it look "fast".
Quote from: Snowtrooper on January 24, 2020, 04:52:34 AM
Might make an interesting variation on the A-1E
Quote from: zenrat on January 24, 2020, 02:28:05 AM
The 'N' wing is also longer, it was lengthened at the wing root end of the wing, not the wing tips.  I happen to have bits on hand so here's a photo of a D wing and a N wing. Republic added a plug to the wing root end which is where the integral wing tanks went, everything else was just moved outward along with the reprofiling of the wing shape.
The N wing would make sense for a long range civilian version, all the space where the guns and ammo storage area are can be converted to have integral tanks in them too.
The undercarriage of the P-47 had a mechanical leg length reducing setup because the u/c leg had to be shorter once retracted into the wheel bay, the N had to have this modified as the u/c leg had to be made a bit longer when it was extended, this is because the wing dyhedral remained the same on both versions.
I didn't know they were different either ! Something new everyday....
Hmmmm.....
How about the power of the jug and the scaled up wings of a Mustang? Or would that be a Skyraider?
Scotaidh
Quote from: kerick on January 24, 2020, 06:44:31 PM
Hmmmm.....
or a Bearcat?  or a Typhoon/Tempest?
Quote from: Captain Canada on January 24, 2020, 06:39:44 PM
I knew the wing shape was different, but not that it was longer, nor the different undercarriage leg length.
Interesting, time to dig that Sword kit out I think ?
How about an N wing with D wingtips added so it was D shape.  That should really confuse them...
Hmmmm.....
Um! XP-72 maybe ---
All R-2800 engines had an integral mechanical supercharger, the turbo-supercharger on the P-47
functioned as the auxiliary supercharger of a two-stage system. The aux blower on other aircraft,
F4U, F6F etc., was mechanical.
