Author Topic: Hawker/Nord Griffon  (Read 780 times)
Offline chrisonord
  • DIDN'T READ THE QUESTION PROPERLY
  • Paint it gloss??......HOW DARE YOU!!!
Hawker/Nord Griffon
« on: September 09, 2019, 01:42:20 pm »
Here's a couple  of pictures  of a kit I  started  building  over  10 years  ago....I  think.  It languished in  the graveyard  for a very  long time  as the engine faces fell out,  and the canopy  scared me. For  the last couple  of months  I  have  been  scouring  the bits boxes  for  its parts, and  tackled the  vacform canopy,  which  is not  as good as it could have been  if someone else  cut it out. With help from Gondor, I  sourced a  pair of as 511's  and found a  centre line  fuel tank that looked  suitably  super sonic  capable.  The aircraft  is an alternative  history  Nord Griffon,  where Nord partnered with  Hawker and Rolls Royce  to make  their  ramjet fighter a  reality using a bery big and powerful  turbojet from Rolls Royce. The aircraft depicted,  is during the  late 50's  and is a test aircraft  that will be armed with different  weapons to see what  works  best basically.  The aircraft  is one of four testbeds, and is in RAF markings,  but will be testing a French  designed  air to air missile.
The model took me a while to get it looking something similar  as I  struggle  with painting and  decals.  I will put some  more pictures  up and a  more in depth backstory  when  I  can, as I  have  a couple  of other  things  awaiting  finishing.
Chris.
https://photos.app.goo.gl/WME2t1YjAAsx7syKA
https://photos.app.goo.gl/Koq9AUmTwRRTtUGk9
« Last Edit: September 09, 2019, 02:43:08 pm by chrisonord »
Online rickshaw
Re: Hawker/Nord Griffon
« Reply #1 on: September 09, 2019, 05:25:26 pm »
That looks interesting.  How did you make it?
Offline 63cpe
  • Targeted for assassination by JMNs
  • Humpty Dumpty was pushed!
« Reply #2 on: September 09, 2019, 10:12:02 pm »
It's looking great! I wonder hoe you made it and from what parts.
David aka 63cpe
Offline Dizzyfugu
« Reply #3 on: September 10, 2019, 12:45:27 am »
I recognize an F-16 fin and nozzle. Wings looks Mirage III-ish, but I am not certain.
Looks very good!
Offline Gondor
  • What-IF SIG
« Reply #4 on: September 10, 2019, 03:01:11 am »
Looks nice, hope we get to see some more pictures of it from different angles etc.
Offline chrisonord
« Reply #5 on: September 10, 2019, 03:25:40 am »
Thanks for the comments  everyone,  I  will be limiting  what angles it can be seen from  as you can see right through  it thanks to the engine  faces falling  out.  They were both resin, and decided  to un stick themselves. Dizzy is correct in  spotting an f16 tail fin, as it was originally  going  to represent  something  a lot more modern. I had to make new canards for it too and replace the front  landing gear. The kit is quite  crude to be honest,  and from what I can remember  of when I  first tackled it,  was quite  badly fitting. The wings are the kit ones by the way Dizzy.
Offline NARSES2
  • Global Moderator
« Reply #6 on: September 10, 2019, 06:12:23 am »
Looks good Chris  :thumbsup:
Decals my @r$e!
Offline chrisonord
« Reply #7 on: September 10, 2019, 07:19:49 am »
Cheers  Chris,
I am reasonably happy with  it as I  have to come  to terms with  the fact my fingers won't get any better.  It looks  like one at least.
Chris.
Online kerick
« Reply #8 on: September 10, 2019, 08:08:13 am »
Looks the part of a design from the 50s. I say keep it coming!
There's someone in my head, but it's not me!
Offline Scotaidh
« Reply #9 on: September 10, 2019, 12:53:10 pm »
I think it looks great.  If you have some black foam rubber, you could fill the void.
I try to learn from the mistakes of others who take my advice.
Offline chrisonord
« Reply #10 on: September 10, 2019, 01:11:58 pm »
That's a good idea  that,  I have some  somewhere I can use.  :thumbsup:
Offline Tophe
    • my what-if models
« Reply #11 on: September 11, 2019, 09:41:16 am »
Congratulations! ramjet models are very rare...
Offline chrisonord
« Reply #12 on: September 11, 2019, 11:05:32 am »
Thankyou Tophe,
This is a very French aircraft  made by a French  model company,  one nthat is quite rare to get hold of too. I  would like  another to build maybe  as a later version  with  newer aam's on it. The matt clear coat  has dried well, and given the  aircraft  the dull metal appearance I  wanted it to have.  I  painted it in dull aluminium, with the airbrush and the matt clear gives it just enough  weathering to the bare metal finish
Offline chrisonord
« Reply #13 on: September 24, 2019, 03:37:18 pm »
Here's some more pictures for you,  I have fitted the  drop tank, but  I am still  repainting the  missiles.
https://photos.app.goo.gl/xQmuzaLgWTibFDuN8
https://photos.app.goo.gl/LYj6cAKja5WX3Hc5A
https://photos.app.goo.gl/b3Gb17UPCUkLbUC88
https://photos.app.goo.gl/6pq6J4LjmeRRbwq78
Offline Tophe
    • my what-if models
« Reply #14 on: September 24, 2019, 07:23:06 pm »
