Author Topic: You can have it in any color as long as it's black  (Read 794 times)
Offline joncarrfarrelly
  • Bertie Bassett
  • What-IF SIG
  • Turn that Gila-copter down!
« on: August 20, 2019, 09:52:40 pm »
“Conspiracy theory’s got to be simple.
Sense doesn’t come into it. People are
more scared of how complicated crap
actually is than they ever are about
whatever’s supposed to be behind the
conspiracy.”
-The Peripheral, William Gibson 2014
Offline NARSES2
  • Global Moderator
Re: You can have it in any color as long as it's black
« Reply #1 on: August 21, 2019, 06:13:49 am »
Ah William's Bros. They did some interesting stuff  :thumbsup:
Decals my @r$e!
Offline zenrat
« Reply #2 on: August 22, 2019, 03:35:53 am »
Looks small, even for a 1/48.  Are you whiffing it Jon?
Offline Rick Lowe
« Reply #3 on: August 22, 2019, 05:06:12 am »
It's tiny - IIRC smaller than a 1/72 Spitfire.
Offline Rheged
  • Growing older is inevitable, growing up isn't!
« Reply #4 on: August 22, 2019, 08:33:15 am »
Is it just my imagination, or does the driver of the machine in the box art look ever so slightly uneasy?
Offline Rick Lowe
« Reply #5 on: August 22, 2019, 02:36:43 pm »
He should be - IRL the prototype disappeared and was washed ashore a couple days later... pilot did not survive.
  • Bertie Bassett
  • What-IF SIG
« Reply #6 on: August 22, 2019, 07:41:25 pm »
Five were built, the kit represents the original configuration, two were built.
The one that crashed was the third built, and was a larger aircraft, 21' 9" wingspan vs.
15' of the first two, and it was quite a bit different in other ways. Numbers 4 and 5
were the same, all three being powered by a Ford built horizontally opposed twin that
used Wright Whirlwind components.
conspiracy.”
Offline Rick Lowe
« Reply #7 on: August 23, 2019, 12:00:03 am »
Ah, ok then - old age and memory failing.  ;)
Hazy recollection of seeing it on the 'Treasures at the Museum' programme.
IIRC it was the death of a test/record-attempting pilot that made ol' Henry axe the project, though.
  • Bertie Bassett
  • What-IF SIG
« Reply #8 on: October 14, 2019, 03:42:07 pm »
Alas and alak the Ford won't be finished, a combo of a busy summer and
getting stalled on the execution of the engines. Tried a number of different
configurations using various plastic tubes, cut down bombs or drop-tanks for
nacelles etc. Some looked too archaic, others too slick and modern.
Also as I work almost exclusively in 1/48, I had little in the way of 1/72,
or smaller, bits-n-bobs to work with.
 :banghead:
Chris, if you'd be so kind to move it over to Current Projects 'twould be
most appreciated. Ta.
conspiracy.”
