Author Topic: English Electric Lightning T55/ FGR 1a  (Read 1759 times)
Offline Gondor
  • What-IF SIG
Re: English Electric Lightning T55/ FGR 1a
« Reply #30 on: September 10, 2019, 02:59:12 am »
Haha,  I  have  some  from the  hasegawa sets but  none of them  look  like  aim-9 B's. I have  looked at  photos and recognition pictures,  but the nearest I have look out of scale,  hence  I  jumped out of the pan and  into the  fire. ;D
Chris.
Deciding what an AIM-9B looks like is partially due to perception of what it should look like and how correct your source is.
The Hasegawa weapons set is set III and parts as I listed earlier are 1,2 & 3 from Sprue A
High Planes do a set of two AIM-9B's in a box as well.
Offline chrisonord
  • DIDN'T READ THE QUESTION PROPERLY
  • Paint it gloss??......HOW DARE YOU!!!
« Reply #31 on: September 10, 2019, 03:20:21 am »
Chris.
I have seen the highplanes aim 9 b's, but at what they cost just for a pair I didn't  want  them that much. With abbit of luck I will be able to assemble  these eduard ones without too much  agro.
Chris.
Offline NARSES2
  • Global Moderator
« Reply #32 on: September 10, 2019, 05:50:04 am »
Chris.
Are you selling tickets for the event Chris ?  :angel: ;) ;D
Nah, best of luck mate  :thumbsup:
Decals my @r$e!
Offline chrisonord
« Reply #33 on: September 10, 2019, 06:01:32 am »
Chris.
Pmsl, I  might  just do that
Offline NARSES2
  • Global Moderator
« Reply #34 on: September 10, 2019, 06:05:48 am »
I always find that with my eye sight issues I get the first couple fine and then one of them will just decide it will not behave  :banghead: You get used to it in the end and soon realise that whilst threatening the part makes you feel better it doesn't actually do any good  ;)
Decals my @r$e!
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #35 on: September 10, 2019, 08:15:47 am »
A technique I've used with equally small N gauge model railway items is to glue them in place with a trace of Evo-Stick, waiting the requisite 10 mins before putting the parts together, and then run superglue into the joint surfaces with a toothpick as a guide.
I did it only this morning, which reminded me to post it on here of course.
Offline chrisonord
« Reply #36 on: September 10, 2019, 08:35:16 am »
Thankyou Kit, I will  add that trick to my armoury
Chris.
Online Scotaidh
« Reply #37 on: September 10, 2019, 12:49:21 pm »
You could use some small styrene tubing cut to length (correct diameter to be found at Evergreen.com) and glue on some triangles.  Fill and round the nose; paint the rear end black  ...
No?  Not an option?
I try to learn from the mistakes of others who take my advice.
Offline chrisonord
« Reply #38 on: September 10, 2019, 01:10:46 pm »
The  B model has some  subtle  detail on them  that I would struggle to  replicate in such a  small  scale,  the nose is nearly flat also
Chris.
Offline PR19_Kit
  • What-IF SIG
« Reply #39 on: September 11, 2019, 05:17:46 am »
...... and glue on some triangles.
And THAT'S the nub of the problem!  :o
Offline chrisonord
« Reply #40 on: September 11, 2019, 05:29:34 am »
Yep, that is pandora's box of the situation alright.
Offline kitnut617
« Reply #41 on: September 11, 2019, 07:08:40 am »
Offline chrisonord
« Reply #42 on: September 11, 2019, 07:51:07 am »
Cheers  Robert,
I haven't  considered  sparrows  until I  read that, but the early  ones  fit within my time frame.  I might already  have some  sparro 1 and 2's in the weapons  boxes.  :thumbsup:
Chris.
Offline Mossie
  • Twiglet doctor
  • What-IF SIG
  • Don't laugh at his mule
« Reply #43 on: September 11, 2019, 01:03:09 pm »
Some background, not meant to influence your choice.  I've just re-read the piece in Battle Flight about Red Top alternatives.  The RAF came to the conclusion that Sparrow III needed a continuous wave illuminator that would be too big for Lightning.  The IR Sparrow V would have worked without it but was a tail chaser only.  Another option investigated would have been to fit it Sparrow the Red Top seeker to give it all aspect capability.
There's an image showing potential locations for Genie which was heavily considered (all the American missiles were looked at and Falcon and Sidewinder were found inferior to Red Top).  The outer wing pylon is quite shallow compared to the one that equipped the Mk.50 series, however it's possible it's for illustration only.
Offline chrisonord
« Reply #44 on: September 11, 2019, 01:50:24 pm »
I have  been  considering  Falcons  for another  aircraft  I  have  lined up, the Boulton Paul p120 or p111, mainly  due  to its compact  size  for such a small  aircraft,  the other will receive  wing tip  rocket pods. They  would  be ok I  was thinking  for the outer wing pylons.  I was thinking  that the U.K and Sweden bought  some  and  wasn't impressed with their  performance,  so worked together  to make  them more usable. Sidewinders again due to their size  and  success rate,  would  make  a useful  addition  to a lot of aircraft  back then.  Redtop and firestreak will also  get used on other stuff I have  waiting to  be built.
Chris.
