Author Topic: Yakovlev Yak-401  (Read 885 times)
Online 63cpe
  • Humpty Dumpty was pushed!
Yakovlev Yak-401
« on: August 18, 2019, 03:01:52 pm »
A new and little more complicated project is this Yak-40 kitbash to a single engined (turbo prop) Pilatus PC-12 lookalike. Have had this project planned for a pretty long time but never had the guts to start it. With this GB I hope to finish it. As for GB eligibility: it's an -2 engine project.
Fuselage and tail enpenage are from an 1/100-ish NuBee Yak 40. Engine is from an Airfix Tucano as is the prop and exhausts. Main wings are from a Zvezda "Rochelle" model from the Disney "Planes" series. This wing needs to be a little more forward of the original wing of the Yak. The "Rochelle" wing is also from the snap tite kind and it's roots are kinda hard to graft into the yak's fuselage. Had to remove the original wingroots of the Yak in the process. In the picture I put in a styrene plates. Those will be covered later by putty to close the gaps. Later I did the same with the gaps in the tail where the rear engine of the Yak used to be.
IMG_20190818_154006826 by Buddy Holly, on Flickr
Next step is to paint the inner fuselage, put in the glazing and cockpit and assemble the fuselage halves. Then put the engine on and the PSR starts.
David aka 63cpe
Online 63cpe
Re: Yakovlev Yak-401
« Reply #1 on: August 25, 2019, 11:41:39 am »
Finally some progress after all putty dried...
IMG_20190825_193514586 by Buddy Holly, on Flickr
IMG_20190825_193525990 by Buddy Holly, on Flickr
IMG_20190825_193559892 by Buddy Holly, on Flickr
The gaps on the wing were a real pain to get right as the plastic is really soft.
First sanding is done, now still waiting for the putty to cure..lucky the weather is quite hot so curing won't take long but still some days (thick layer of putty)
Prop also needs some reshaping...
David aka 63cpe
Offline jalles
  • Makes own decals
« Reply #2 on: August 25, 2019, 01:25:25 pm »
That's looking great! I would have never dreamed that combination would work so well  :thumbsup:
Offline Dizzyfugu
« Reply #3 on: August 25, 2019, 11:35:31 pm »
Oh, I like that. But the wings look a little wee?  :o
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #4 on: August 26, 2019, 05:05:12 am »
Yes, a couple of inches longer would work pretty well......  ;D ;)
Offline zenrat
« Reply #5 on: August 26, 2019, 05:14:07 am »
Thats looking, ummmmmmm, interesting.
 ;D
Online 63cpe
« Reply #6 on: August 28, 2019, 01:30:52 pm »
Yeah, the wings were a bit too small. So, took the Dremel and cut about 1,5 cm out off the fuselage between wings and where the engines used to be. Will post pics tomorrow as the tail is curing. Think it's more balanced now.
David aka 63cpe
Offline Dizzyfugu
« Reply #7 on: August 29, 2019, 12:51:15 am »
You could also compensate for the small wings with a Delanne arrangement?
The fuselage comes from a 1:100 VEB Plasticart Yak-40, right?  :o
Online 63cpe
« Reply #8 on: August 29, 2019, 01:49:02 pm »
Sitrep:
IMG_20190829_071736128 by Buddy Holly, on Flickr
IMG_20190829_071820535 by Buddy Holly, on Flickr
IMG_20190829_071907553 by Buddy Holly, on Flickr
IMG_20190829_071929016 by Buddy Holly, on Flickr
After the fuselage was shortened...
@ Dizzy: yes, this is the 1/100 nu-bee Yak 40
David aka 63cpe
Offline NARSES2
  • Global Moderator
« Reply #9 on: October 16, 2019, 06:28:00 am »
Moved as requested
Decals my @r$e!
Offline NARSES2
  • Global Moderator
« Reply #10 on: October 16, 2019, 06:31:28 am »
Moved as requested
Decals my @r$e!
Online Tophe
    • my what-if models
« Reply #11 on: October 16, 2019, 10:47:12 am »
Good, and it will be probably perfect when completed :thumbsup:
