Author Topic: Das Werk  (Read 777 times)
Offline NARSES2
  • Global Moderator
Das Werk
« on: July 31, 2019, 06:16:01 am »
In a possible sign of a reaction to the super detailed model which you spend an age on fitting the interior out and then can't see a thing Das Werk are releasing some of their 1/35 Panther kits without the normal interior fittings.
Has the pendulum started to swing or did they simply not have enough interior sprues moulded ?
Decals my @r$e!
Offline zenrat
Re: Das Werk
« Reply #1 on: August 01, 2019, 05:33:41 am »
Miniart (I think - correct me if i'm wrong) produce two versions of their more detailed armour - with and without interior.  A good idea if you ask me.
But if you were not satisfied with the trials and tribulations of fitting out a 1/35 interior, I have a Hobby Boss T34 with full interior detail (including engine & transmission) in 1/48.
Offline NARSES2
  • Global Moderator
Re: Das Werk
« Reply #2 on: August 02, 2019, 06:13:55 am »
I also think it's a good idea.
Interestingly the IBG Crusader AA tank I'm going to build has taken the minimalist approach to the running gear and track assembly which is one of the reasons I bought it.
Decals my @r$e!
Offline zenrat
Re: Das Werk
« Reply #3 on: August 03, 2019, 05:22:08 am »
I don't like rubber band tracks but I can see that the novelty of working individual link tracks would very quickly wear off.  Link and length seems to be a good compromise in 1/35 and 1/48.
Offline NARSES2
  • Global Moderator
Re: Das Werk
« Reply #4 on: August 03, 2019, 07:00:04 am »
The IBG Crusader has the tracks moulded complete with the inside of the running gear and you attach the individual outer running gear parts to that. Very simple and in 1/72 very practical especially as the Crusader has minimal track sag, if any.
Decals my @r$e!
Offline Old Wombat
Re: Das Werk
« Reply #5 on: August 04, 2019, 02:32:56 am »
Yes!
Offline rickshaw
Re: Das Werk
« Reply #6 on: August 05, 2019, 06:50:04 pm »
I actually prefer the rubber band style of track - if they are molded well,  I look with horror at the amount of work required by individual track links or even link and length tracks.  I am, I know, a lazy modeller.   :banghead:
Offline NARSES2
  • Global Moderator
Re: Das Werk
« Reply #7 on: August 06, 2019, 06:17:43 am »
I don't think I ever found a practical solution to joining those old Airfix tracks. In the end I'd be nice to my mum for a few days and she'd sew them together for me  :thumbsup:
Decals my @r$e!
Offline zenrat
Re: Das Werk
« Reply #8 on: August 07, 2019, 05:40:39 am »
I used to put  the join over a return roller behind a skirt if possible, or under road wheel if not, and then flood it with tube glue.  It made a sticky mess which adhered to the styrene part it was sat on/under.  Never very satisfactory.
