Weight is in, door is in, and I glued it all together and threw a splint on it and a couple shims. (oops heheheh , I'll do better next time, this my first "cut and extend.." lol )
Going to start on the wings next then maybe get the engines started so I can figure out the best way to glue the extras on.
Also thinking about giving this a proper name. This would be, if I'm correct, the "Caravelle 13." Are the French superstitious? Perhaps I can make it the "14." Sud Se-213-13(or 14) Super Caravelle or more likely simply the "Caravelle 13 (or) 14".
Lastly, on an interesting note.... I was looking at the Caravelle 12 and counted the windows then counted mine. 21 each (per side). HMM.... thing is, mine is considerably longer (I did a direct comparison with an image the same size as my model parts). Anyway... so.. same windows, yet mine is longer.... this tells me the window sizing/spacing is off on the kit. They must also be off on the transfers as they are meant to overlap the clear windows. Of course, none of this is a problem here in the alternate universe, but notable.
