avatar_Tophe
Micro-winged P-38s
Started by Tophe, February 28, 2019, 10:16:54 PM
And now an Ekranoplightning P-38X-114:
Thanks!
And, decades before the Harrier was the VTOL Harrining:
For ships, boats, the screw propeller vs water wheel competition was won by the propeller, and for airplanes, this was won as well, but which was the competitor? WW-38!
The SW-38 Single Wheel Lightning was also designed but failed to fly:
And thanks to loupgarou explaining me what is the Zero Length Launch take-off, here are the ZeLL-L Lightnings:
Paddle wheel P-38's are brilliant  :thumbsup:
Quote from: NARSES2 on March 13, 2019, 07:03:43 AM
Needs to be built in polished wood, brass and copper. That would look very steampunk. Oh, and lots of rivets!
Thanks!
Quote from: Nick on March 17, 2019, 11:42:35 AM
Would you accept an X-15 as being unconventional?
Quote from: NARSES2 on March 18, 2019, 07:38:57 AM
Kit has conferred and we are ok with that Nick.
The P-38X-15 had micro-wings because this is enough at Mach 7:
With lift mainly provided by 3 balloons filled with Helium*++, the Lightnip had a maximum speed of 10mph:
Oh, I realize that, years ago, I already Drew Magnus Effect Lightning and Cyclogyro Lightning, differently:
63cpe
Wahahaha!  :wub:
Wonderful!
David aka 63 cpe
63cpe
As a logical folluwup of the Flettner Rotor experimental, I plan to build a fanwing.
Not clear on all parts but probably put an 1/48 Alouette II canopy in it eventhough it will be in 1/72 as all my builds.
I simply can't make the fanwing within the GB time frame..
David aka 63cpe
If you have no time to build it, I may have time to draw it, Copyright 63cpe of course ;D
The source I found is http://fanwing.com/ is it that?
