avatar_chrisonord
Boulton Paul P 120 point defense interceptor.
Started by chrisonord, February 15, 2019, 01:42:53 PM
After my near blind purchase of the P111/111a and P120, I thought perhaps they could be put in service as point defense interceptors. Possibly mixed propulsion, rocket motor to get it to altitude and either pods of unguided rockets or a pair of license built falcon missiles, on over wing pylons. I originally thought of using firestreaks, but they are to me, too big. I haven't looked in to when the Falcon missiles were brought in to service, but what if they worked right first time out and became a success story, much like the sidewinder did, and the British bought some to arm their current fighters of the time. It is totally a what if idea I know, but the size of the aircraft with an advanced nene or newer more powerful engine, it would cause havoc to a Soviet bomber formation. Just had a look and the AIM-4 Falcon come in to service in 1956, also Hughes made the AIM-26 falcon, a nuclear armed version, one or possibly two could be carried by the P120/P111.
Chris I think that's a good idea, especially as I had a similar one  ;D
I built the AZ (Freight dog) SR 53 as an RAuxAF point defence fighter to be used to defend airfields in a last ditch scenario.
Cheers Chris,
I will look at how best to replicate the rocket motor too, as I am thinking of putting an external jettisoning pod on the lower rear fuselage. AIM-26 nuclear falcon missiles could be the way to go too.
Falcon and Sidewinder entered service in 1956. Firestreak in 1957. Nuclear Falcon didn't come along until 1961.
Original AIM-4 Falcon weighed 119-135lb depending on the version
Nuclear AIM-26 Falcon weighed 203lb
Firestreak weighed 300lb
Sidewinder AIM-9B weighed 155lb
Genie weighed 822lb
The P.120 didn't have a radar, which would be needed for SARH-guided AIM-4 Falcons, Nuclear Falcons, Firestreak and Genie. Firestreak needed a radar to point the seeker at the target, and Genie needed it for precise trajectory calculations. This means that IR-guided Falcons and Sidewinders are the only realistic option. If you wanted Nuclear Falcon, you'd have to have a what-if IR-guided version.
The original Falcon wasn't a 'failure' as such in it's intended role, i.e. destroying lumbering bombers. It got a bad rap because it's first combat use was in dogfights over Vietnam where it's long cooling time (6-7 seconds), one-shot cooling (once cooled, it had to be fired within 2 mins otherwise it was dead-on-the-rail), lack of a proximity fuse and complicated controls made it a royal PITA and much inferior to Sidewinder. None of that matters, however, if you're cruising up behind a Tu-4...
Personally, given the early date and limited potential of the P.120, I'd be inclined to go for unguided rocket batteries, probably on cropped wingtips similar to the P.111.
Personally I find the idea of nuclear weapons going off somewhere over the East coast slightly frightening, mind you the alternative is perhaps even more so,
Quote from: NARSES2 on February 17, 2019, 04:20:13 AM
Well they tested a live Genie in 1957. It detonated at 18-20,000 ft and observers on the ground directly underneath it were unharmed and didn't take dangerous radiation doses either. The Genie warhead was 1.5kt whereas the Nuclear Falcon used a much smaller 0.25kt warhead, so somehow I think Hull would have been spared excessive sunburn.
I'd be more worried about:
a) An RAF interceptor crashing with one on-board in peacetime. Apparently it was discovered that it was possible to set off a Genie by dropping it hard enough. Some 'urgent modifications' ensued... :o
b) The results of a near-missed Soviet bomber crashing in one piece with it's nuclear bombload active. The result of a near miss would be to kill the crew with radiation in minutes, but that wouldn't stop them from arming their bomb(s) as a final act. Even if they didn't the results of a crash could have a wide range of outcomes, none of them good...
Scotaidh
Quote from: Weaver on February 17, 2019, 04:52:21 AM
Not to mention the devastating effects of the EMP these days ... In the 50s it would have been an interesting side effect, but now ...
So, over wing aim-4's  should do the job. There was an infrared version that in the wiff world, should do. I can arm the P120 with those, and the P111 with unguided rockets.
Quote from: chrisonord on February 17, 2019, 08:14:32 AM
That makes sense: switching over to missiles means the P.120 can exploit the extended wingtips for a bit more altitude performance.
There really were IR-guided AIM-4s (AIM-4B,C,D & G), it was just the AIM-26As & Bs that were radar-only. The original plan was to have IR versions of AIM-26 but they were cancelled, so it was clearly feasible.
I will have to have a look at podded unguided rockets for the 111, not sure how over wing pods of rockets would fare, so maybe, a single under fuselage pod might work.
Quote from: chrisonord on February 17, 2019, 10:04:03 AM
Well it's got cropped wingtips hasn't it? If so, I'd put the pods there: as far away sideways from anything in front of them as possible...
I will have a look at what was in use in the mid fifties, and  see if it is feasible, if not, I will make something bespoke for it.
Fireflash? Like others it'd need radar though.  It might be possible to make a thimble fairing, like with some MiG's.
https://www.hannants.co.uk/product/PAVU72175
Fireflash looks to be quite a large missile, is it similarly sized to the firestreaks, as they are way to big for these.
It'd be interesting to see how they discovered that.
I suspect some of my more lurid tales of explosive tests having gone wrong would pale into insignificance by comparison!  :o :o :o
