Author Topic: Ebay: Hawker P.1214 X-Wing 48th 3d printed  (Read 1061 times)
Offline The Wooksta!
  • Resident Soup Dragon
  • What-IF SIG
  • Would you risk it for a chocolate biscuit?
« on: October 21, 2018, 05:25:15 am »
Found this on ebay a few days back:
https://www.ebay.co.uk/itm/HAWKER-P1214-1-48-MODEL-KIT-12-x-10/163310941923?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160927153312%26meid%3Db10964f89f3d4befa1417c70364fa7c5%26pid%3D100013%26rk%3D4%26rkt%3D12%26sd%3D142981069870%26itm%3D163310941923&_trksid=p2047675.c100013.m1986
Now it looks rough and it's really just a desktop model, but AFAIK, it's the only one in the scale and with some work, you could get something out of it.
I've used this guy before - it's where I got my Blake's 7 Scorpio from - and service isn't too bad although I've a feeling they're printed to order.
"It's basically a cure... for not being an axe-wielding homicidal maniac... the potential market's enormous!"
"Please dial *617 at this time"
"Now then, Butch Harry. Tell us about Fulham."
The Plan - a Blog
www.whatifmodelers.com/index.php/topic,34762.0.html
Offline kerick
Re: Ebay: Hawker P.1214 X-Wing 48th 3d printed
« Reply #1 on: October 21, 2018, 05:52:40 am »
Now that would look good sitting on the shelf!
There's someone in my head, but it's not me!
Offline Gondor
  • What-IF SIG
« Reply #2 on: October 21, 2018, 02:32:51 pm »
That's a good price.
Offline Doug K
  • Makes own decals
« Reply #3 on: October 21, 2018, 04:12:34 pm »
A very good price, tempting
Offline TomZ
  • aka Zuid99
    • Airwar 1946
« Reply #4 on: October 21, 2018, 11:24:20 pm »
I've got his 1/48 Hawker P-1154 model.
Looks about the same as this picture. Not a bad model but will need a lot of work to get a decent model out of it.
It needs a LOT of smoothing as the 3D printing is not very high res, so there are ridges all over the model.
I'm not sure how I will tackle that as the print is done is a rather hard Nylon plastic that doesn't sand very well. I've been thinking about covering the whole model in a thin layer of putty and then sanding it carefully. Not sure how that will turn out though.....
TomZ
Offline Hobbes
  • Stores peanuts in his mailbox
  • What-IF SIG
    • Acme Engineering
« Reply #5 on: October 22, 2018, 12:03:32 am »
That's what I've been doing with my low-res printed parts: Cover them in filler primer, then sand flat. That works well as long as there's no fine surface detail to preserve.
Offline TomZ
  • aka Zuid99
    • Airwar 1946
« Reply #6 on: October 22, 2018, 12:19:22 am »
Harro,
What primer do you use for this? Mr. Surfacer?
TomZ
Offline Hobbes
  • What-IF SIG
    • Acme Engineering
« Reply #7 on: October 22, 2018, 01:24:27 am »
'Alabastine spuitplamuur' from a spray can.
Offline TomZ
  • aka Zuid99
    • Airwar 1946
« Reply #8 on: October 22, 2018, 04:15:49 am »
thx
Offline NARSES2
  • Global Moderator
« Reply #9 on: October 22, 2018, 06:33:15 am »
Very much so. I expected to see it a fair bit higher.
Decals my @r$e!
