P.1154
Started by Devilfish, September 06, 2018, 01:13:36 AM
Devilfish
What started as a "what am I going to do with this Monogram 1/48 AV-8B with a missing canopy?" idea to make a supersonic Harrier, has turned into a full blown P.1154 scratchbuild!
Initially I planned to use all of the AV-8B kit, just move and modify things, but it wasn't that simple, so a new plan was needed.
A search through the spares turned up a pair of Phantom intakes.
Then a Tornado main fuselage, which I narrowed
20180904_192750 by Paul Carter, on Flickr
20180904_203022 by Paul Carter, on Flickr
And added nozzle ports
20180904_234311 by Paul Carter, on Flickr
My next problem was the lack of canopy.  Nothing I had in the spares would fit, and tbh, with everything else, the -8B's nose just wasn't doing it for me.  So, back to the spares box, and out with a TSR2 cockpit area....
While I was there, I found an old pair of Sea Harrier wings, which looked better than the big 8B wing....
So, this is where I'm at.
2018-09-05_10-15-25 by Paul Carter, on Flickr
All in 1/48, I take it?
Looks like MAJOR plastic engineering going on there.  :o
That's a real Frankenstein creation - bits from everywhere.
Devilfish
Quote from: zenrat on September 06, 2018, 03:09:34 AM
5 different kits, and counting!!
Doug K
Oh my that does look good.
Quote from: Devilfish on September 06, 2018, 03:10:42 AM
Wow !
Scotaidh
Oh, I'm so following this one!  :)
Devilfish
The nose section has been attached, and I've sanded and polished the TSR2 canopy, so it is clear and the windscreen frames have been removed.
2018-09-09_10-15-39 by Paul Carter, on Flickr
Devilfish
Started applying Milliput over the fuselage to level it all up.  Not used this medium for years, so it's a learning curve.
20180911_215402 by Paul Carter, on Flickr
 :o Fred's right, that really is a Frankenplane! Great stuff! :thumbsup:
