Westland-Fairey Rotocrane HC4
Started by PR19_Kit, July 10, 2018, 03:28:28 PM
The W-F Rotocrane in its various marks has been the RAF's main heavy lift 'helicopter' since the late 60s. Originally just a stripped down version of BEA's standard Rotodynes in its HC1 from, the Rotocrane was developed into a pure cargo carrying airframe, with most of the Rotodynes fuselage structure stripped away, but maintaining the revolutionary vertical lift capability combined with a 220 kt cruise speed in aeroplane mode, by far the highest for such aircraft worldwide.
Later marks offered increased wing span, higher powered Roll Royce Tyne engines and more sophisticated cargo handling fits. The latest versions, the HC4s, have 'all glass' cockpits together with a fully digital control system and enhanced defensive systems.
Without doubt the RAF's most famous Rotocrane is 18 Squadron's ZA718, named 'Bravo November' due to its heroic actions when it was coded as such during the 1982 Falklands War. 'Bravo November' was the only Rotocrane to escape the sinking of the MV Atlantic Conveyor on the 25th May 1982, and was the only heavy lift aircraft available to the British Forces during their liberation of the Islands. Subsequently having been upgraded twice and having served in many theatres of combat 'Bravo November' is assured of its place in the RAF's history and a place in the RAF Museum is guaranteed when it's retired.
The model consists of two Airfix Rotodynes, both suitably hacked about to remove most of their fuselages, and with stretched wings (WHAT a surprise.... ;D) The Tyne engines come from a Revell Transall C-160 and the twin booms (cue cheers from Tophe.... ;)) come from a Heller Noratlas, as does the landing gear.
The cargo depicted is an 00 gauge 40 ft Hi-Cube container from C-Rail that's been modified with a side access door.
The rotor system could come from many sources, but the current favourite are all six blades from a Chinook married to a hub from a Super Stallion.
Watch this space for pics, some maybe as soon as later this evening.  ;D
Fantastic!  Love this idea.
-Dave
jalles
I can't wait to see this! Waiting impatiently for pictures.
Here's the first build pics.
The container fully assembled, it took at least an hour.....  ;D
The basic structure of the Rotocrane. It's not immediately obvious but the fuselage is lengthened forward of the pylon by around 3-4 window bays. And the tail's cut off totally of course.
A rough approximation on how it'll look when assembled (with luck....)
tigercat
Looking good .
The Container reminds me of the RAF chapel one at the TAG museum.
This looks like fun! I'll be watching!  :thumbsup:
Holy hell I love the conex....    ;D ;D
To borrow a phrase, "Keep going!"  :mellow: :mellow:
Quote from: PR19_Kit on July 10, 2018, 03:28:28 PM
This is like a PR19_Kit (designer) trademark! Good! :thumbsup:
Kit at the end if this build we need a pic of the leftover parts and a summary of what you plan to do with them.  There's at least one more whif to be had out of them?
Quote from: kitbasher on July 10, 2018, 11:32:34 PM
Yes Dave, I've been wondering about that myself.  ;D
The bits of Rotodyne fuselage left over make up a VERY short 'dyne, which has some possibilities for sure.  ;)
An interesting concept, Kit.  I note you have stated that you aren't going to use the 'dyne's tail.   What are you going to use instead?  The 'dyne appears dependent on having one...  ;)
Noooo Brian, I said I'd cut it off, I didn't say I wasn't going to put it back again somewhere else.  ;D ;)
Kit, how does that Sea-Can scale out when you're doing 1/72, is it a bit smaller ?
