avatar_McColm
Airbus A400M tilt-wing idea
Started by McColm, August 27, 2017, 11:07:48 AM
I've been reading the 'Aviation Archive- VTOL Aircraft'.
The donor kit will be a 1/72 Airbus A400M Grizzly.
There seems to me that there are two designs to choose from. Either a tilt wing rotating 90° or something similar to the
  F-8 Crusader fighters' wing.
Since the kit is a problem child from the beginning, either a new wing or work with what you've got.
Using the existing wing as this is a single piece,  a pair of hydraulic arms similar to the Hiller X-18 example can be scratched built.
At least there'd be a better chance of the wing 'fitting' than it does with the OOB kit......
How about 1/48 Osprey wings on a 1/72 A400 fuselage?
Quote from: zenrat on August 28, 2017, 02:20:36 AM
They'd be some BIG props for sure!
Quote from: McColm on August 27, 2017, 11:07:48 AM
You mean that the two options are either the wing tilting or the engines tilting!
You can go down the route of the Canadair CL-84 Dynavert,, Hiller X-18. or
LTV XC-142A tilt wing or the Curtiss-Wright X-19 and Bell X-22A where the engines tilt.
Another idea is a Heliplane. I'm building one at the moment using a C-130 with a
C-121 triple tail fin, the jet engines are
TF-33s with the main stack and rotors from a Mil-26 Halo. The Roman nose has been replaced with the resin nose cone off a Cammett BAe Nimrod AEW.3, this might work on the Grizzly.
I think that I might have another Mil-26 Halo in the stash, the wings can be cut down to accommodate a pair of 1/48 turbofans or just a pair of turboprops, as for the tail twin or triple fins. Although I might keep it the same as in the kit. As for the the main landing gear, a pair of hydraulic skis  :banghead:
