LF 1/72 C-130 wing tanks
Started by PR19_Kit, August 15, 2017, 02:39:21 PM
I'm looking for a pair of C-130 wing tanks. IIRC they're the same on the E/K or J versions so I'm not fussed if they come from an Airfix or an Italeri kit.
I thought someone did them in resin, but I can't find any.  :banghead:
IIRC, it was Heritage Aviation.  Which means it could be Alleycat now.
Quote from: kitnut617 on August 15, 2017, 02:48:24 PM
Thanks for that Robert, but despite the VAST range of stuff that they do, they don't do those tanks, not at the moment anyway.
Have you considered scaleoraming 1/48 tanks or do they need to be specifically C130 ones?
Quote from: zenrat on August 16, 2017, 02:49:50 AM
I hadn't, mainly because I don't 'think 1/48' normally. I have a 'scale filter' that's set at 1/71 scale......  ;D
They don't actually need to be C-130 tanks, no, I just want BIG-ish ones.
Kit, are you in a rush for them? I've got a C-130 vacuform conversion set somewhere in the stash. It has a load of parts to build just about any variant of early C-130 (pre-C-130J that is). I'll look for it and see if it has tanks but it might take a while to find it (on the weekend).
I was looking through the various website and found OzMods does a C-130A conversion. It has some tanks but the 'A' had them installed outside the outer engines
Another thought, some time ago I was looking for something similar, I was looking for under wing tanks to go on my Sunderland project. I went with a pair of 1/48 F-101 tanks -----
Oh hell!  :banghead:
I've got that same vacform conversion kit somewhere too! The one that lets you build the ski-equipped USN version that they flew in Antarctica? I didn't think of looking at that, but I will now. Thanks for the tip Robert.  :thumbsup:
I inherited a box of 1/48 scale underling stores. There are loads of tanks....if you give me rough dimensions I'll see if there are a suitable pair....be at the weekend though as away at the mo....maybe length and diameter....H
Magic Hank, thanks, there's no real rush for them as yet.
1/72 C-130 tanks are around 105 mm long and 15 mm in diameter, with rounded noses and pointy tails.
Hi Kit,
You are welcome to have my 1/72 Airmodel vacform C-130 tanks. Free of charge.
Steven
Thanks Steve, but I think those are the ones that I have already, the ones that kitnut617 mentioned above.
Yes,
They come from the same set. :banghead:
Problem solved.  :thumbsup:
While trawling through The Loft I found to my amazement I had an original Airfix Herk, complete with Bloodhound missile (and guard dog...) which has TWO complete fuselages, so I now have the required tanks.
Thanks for all the offered ideas etc.
Just got home.....sure you don't need me to look for any spares...?
Quote from: Army of One on August 18, 2017, 04:20:25 PM
I'm OK now thanks Hank, the old Airfix ones are pretty darn close to the much newer Italeri ones, thank goodness.
But thanks for the offer anyway.  :thumbsup:
