avatar_Librarian
Japanese Mistel
Started by Librarian, July 03, 2017, 03:23:53 AM
Librarian
Something else I've been fiddling with...spot the changes ;D:
Had some fun painting a stylised cherry blossom on the warhead but don't really like the result.
Big thank you to Scooter for the sizing help :thumbsup:
Librarian
Been stalled for a coupla days 'cos I can't decide on camo :banghead: Love to do one of those frankenschemes seen at the end of the war...real mish-mash of colours. Might just paint the Mistel like a bomb...no markings but the 190 could be camo-ed like the earlier P-47. Coin-tossing time Harvey ;D
Would you even bother painting the weapon?  Do it in NMF maybe with lots of different metal shades and maybe even some corrosion?
Librarian
...or maybe, being based on the Ta-154, wood/plywood finish ;D.
FW190 was looking just too 190...that cowling had to go, so:
Aaaaah...that's better. G&T time methinks :wacko: I'll have to write in some reason why the upper-decking guns have been omitted :banghead:
nighthunter
Simple, Kamikaze, didn't need them, saved for imminent invasion of the home islands.
Quote from: Librarian on July 04, 2017, 12:12:52 PM
...or maybe, being based on the Ta-154, wood/plywood finish ;D...
I thought it was a Ju88.  Probably made that mistake because it's in the wrong scale... :mellow:
So, lots of woodgrain painting.  Go on, you know you want to...
Librarian
Quote from: nighthunter on July 04, 2017, 07:47:04 PM
Much as I have enormous respect for the volunteer pilots of the special attack squadrons they are NOT taking part in my whif-world. This combo will also be on the Ostfront, the 'bomb' being used against the factory complexes of Magnitogorsk.
nighthunter
#7
Quote from: Librarian on July 05, 2017, 05:31:18 AM
Hai, Librarian-san, I understand, 'twas just a suggestion. Other option, they were removed to save weight and to keep pilots from engaging in unnecessary dogfights on their return home.
Or you could put a couple of brass tubes poking out near the top in the upper cowl intakes as barrels, that way they haven't gone anywhere. Still there but different. ;)
Librarian
Ditched the 190...not a fan to start with, and then couple that emotion with a depressingly bad model kit. I was warned off the Trimaster/Dragon/Revell mold years ago. My one and only  foray into 190 territory was with Tamiya (practically a snap-fit kit :thumbsup:) Used this one 'cos it came with the Mistel combo. YUK!!
Tried to improve the looks but I was just not enjoying the experience :banghead:.
Anyway, chosen a better alternative so will start on that when it (the weather) cools down a bit.
nighthunter
Better luck with the replacement!
On the plus side, using something other than an FW190 will make it harder to identify (although it fooled me as it was - but that's not too hard).
If google translate is to be believed Mistel in Japanese is Yadorigi BTW.
How about a rising sun on the nose of the weapon?  Red centre on a white background with red rays coming from it?
nighthunter
Quote from: zenrat on July 06, 2017, 03:51:53 PM
That's brilliant!
Librarian
Took some days off with models placed out of sight, out of mind. Needed a break as the heat and short sleep periods were wearing me down.
I HATE giving up on a model. Apart from the above I was battling the 190 kit itself and the cowling issue. 190 is back on, but removed the cowling to have a good think. Getting there but its taking a lot longer than normal....
Librarian
Hello children. This is Masamune Mistel shortly before wiping the smug grin off Gordon's face by scoring a direct hit on the engine sheds at Sodor....
[imgwidth=600]http://[/img]
Seriously, finally managed to get some work done. Not sure about the face...supposed to be a stylised Stalin but looks more like Zapata :banghead:. 190 is starting to look nice...getting there :thumbsup:.
