avatar_seadude
Soviet Space Battlecarrier
Started by seadude, February 22, 2017, 07:00:01 PM
seadude
Several months ago, I won the following kit in a raffle at my local model club meeting. One idea I had was to whif it into a non-SBY universe Cold War era Soviet space battlecarrier. Though instead of the classic red hull color, I chose to paint mine in an olive drab green scheme. I know, it probably would've looked much cooler in a red color scheme to match the Soviet communist regime, but I couldn't afford the money to buy new bottles of red paint, so I had to use whatever was most abundant already at home. Flight deck is painted Gunship Grey. The black lines on the flight deck indicate aircraft elevators. There's one black line silhouette at the rear of the ship which indicates where a retractable gun turret will be. Trying to paint this model is a beast as everything needs two coats of paint.  :banghead: I will add 3 small fighters that are spare parts from another kit. They are 1/500 scale even though the main ship is 1/1000 scale. You can see one of the fighters on the flight deck. I don't think it looks too bad. It looks like it might fit/work on the flight deck.
More pictures to come in the next few days.
Cool. A lot bigger than I thought it would be !
seadude
Quote from: Captain Canada on February 22, 2017, 07:42:25 PM
Yeah, at 1/1000 scale, I thought the model would be significantly smaller. What a surprise that it wasn't.  :o Overall, I'd say it's about maybe 16 inches long.
I likes this, wonder if Bandai will listen if I ask them for a 1/72nd scale one :wacko:
Chris.
Quote from: chrisonord on February 23, 2017, 02:27:04 PM
Chris.
You must have some BIG shelves Chris, that'd be over 18 feet long!  :o
seadude
I wouldn't call it 100% done, but rather 99.9% done. After taking pics and viewing them on my comp, I realized there are a few "tiny" orange hull spots that need touch up.  :o  But anyway, here she is, my "unofficial Soviet Group Build project".  ;D
U.S.S.R.S. BAKU
"KIEV CLASS" BATTLECARRIER
BATTLECARRIER SPECIFICATIONS:
LENGTH OF SHIP:  390 meters
WIDTH: 67-70 meters
ARMAMENT:
a) 4x Main 28cm triple gun beam turrets (One of which is retractable.)
b) 4x 13cm triple gun beam turrets (2 on each side of the ship.)
c) 2x 6-tube missile launchers (Behind the towering bridge superstructure.)
d) 2x retractable upper weapon decks (Each deck has 1x 28cm triple gun beam turret, 2x 13cm triple gun beam turrets, and 16x VLS missile tubes)
e) 2x retractable lower weapon decks (Each deck has 2x 13cm triple gun beam turrets.)
FIGHTERS: 30-40 "Krechyet" (Gyrfalcon) class fighters
The upper weapons deck (Center of picture below.) as originally for the BANDAI model which can be interchanged with a portion of the front flight deck.
My model pics below:
Here is the upper weapons decks which would normally fit into the flight deck.
Closeup of the upper weapons decks and it's relative position on the flight deck.
Lower weapon decks.
The Chaos
seadude
Some better and slightly improved pics of the finished model that I took several days ago.
seadude
Nice.  Looks good with a red star.
Joe C-P
Most excellent work, comrade! Decadent imperialist Westerner shall tremble to enter space with such a glorious Soviet wessel
Quote from: PR19_Kit on February 23, 2017, 03:26:10 PM
Chris.
At least I shouldn't have too many problems with fiddly bits Kit  :rolleyes:  :thumbsup:
Quote from: chrisonord on September 05, 2017, 04:15:53 AM
I don't know about that mate. Just gives them loads more room for tiny bits that need to be fitted  :banghead:  ;D
You could get inside and do all the 'not so fiddly bits' from in there.  ;D ;)
