avatar_Army of One
1/350 scale aircraft.....
Started by Army of One, January 24, 2017, 02:01:00 PM
What do people do to replicate the canopy on these small solid plastic aircraft.......I've thought of black....silver....light blue but discounted light blue due to colour schemes.....any suggestions welcome....cheers
#1
I have found the best material for clear canopies in 1/350 scale aircraft is clear plastic.  In 1/700 scale you can get away with painting canopies (light blue usually works) but in 1/350 I offer clear looks best.
So what to do?  Get a sharp blade and cut off/out the solid kit canopy and replace with a clear canopy from a kit that has them, or file a clear solid piece of plastic and glue into place.  Yes can be time consuming, but worth it IMO.
Get the magnifying glass handy!
Here are some examples I did, sorry they pictures are not the best.
Scratch 1/350 Convair SeaDarts.  The canopy is from a Trumpeter 1/350 A-7 kit, which has a separate sprue for the canopy.  The Trumpeter kits have a high quality, hollow canopy.
The cut and file method.  Scratch 1/350 F-102, with the fuselage being partially from a A-7.  The canopy is the top half of a F/A-18 nose cut down and filed to shape.  The F/A-18 had already been sacrificed to supply P6M Sea master engine nacelles.
The F-102/TF-102 production line.  Note the clear noses. Before the canopies were installed.
Clear noses for the prone bomb aimer?
;D
Wow...some great work there.....the kits i have are Tamiya 1/350 designed I think for the Enterprise carrier kit......I think I'm tempted by black for the glass.....
Quote from: Army of One on January 27, 2017, 05:46:52 AM
A light black would likely be fine for the usual gray aircraft as would be seen on a modern or semi modern USN carrier deck. A true black might be too much contrast.  As you can see from the photo I have struggled and experimented for years with this dilemma in 1/700 scale.  Black, dark gray, silver, light gray, blue..
The Harrier II near the upper left looks pretty good, with a light black canopy.  The blue ones were never quite right, and would be even more pronounced in 1/350.
All the below are 1/700 (except the 1/350 F-102 in the rear)
Good luck!  Dave
Wow......many thanks.....much appreciated....
You are right about that light black  :thumbsup: The silver on the F.111 N ? looks o.k. as well
Quote from: NARSES2 on January 28, 2017, 03:11:06 AM
Thanks guys, glad I could help.  For the UK F-111B (aboard the stretched Ark Royal!), I used light gray for the canopy- likely a ghost gray.  It does look good, but perhaps would not work as well on a lighter gray USN aircraft.
-Dave
