HMLS Devastation
Started by Caveman, May 25, 2016, 01:11:04 PM
Caveman
Thought I'd give this a bash (boom-boom).  Ive got a churchill firefly that I had bought with the express intent of turning into a land ship after being inspired by a landship I saw on here but since cannot find!
I have no boaty bits so they will have to be scratch built or bodged from the bits box.
I was just having a flick through ship bucket and came upon HMS Thunderer, which was one of a pair of Devastation class.  They have a nice compact super structure (easy to bash?) and are similarly proportioned to the donor "hull".
https://en.wikipedia.org/wiki/Devastation-class_ironclad
So the intent is to build something akin to an HMLS Devastation, in the rather fetching, turn of the century Oxide Red below waterline (not sure where this will be on the churchill..., Black hull, white upperworks and sand funnels.
"Bits"
secretprojects forum migrant
That sounds interesting !
Caveman
Thanks, I hope it will look interesting too.
Found some perfect pipe for the turrets too. A bit of pvc pipe. Not sure how well it will play with glue, paint or other plastic parts though. Anyone got any ideas?
Not sure about that one. Test it I guess.
Quote from: Caveman on May 26, 2016, 04:58:12 AM
PVC is very difficult to get any kind of glue to stick to.  :banghead:
It's relatively flexible so epoxies just crack away from the surface and it doesn't 'melt' like styrene does with solvents.
Caveman
Bum.  Might use it as a former to wrap some thin styrene around then.
loupgarou
In DIY stores you can buy PVC glue, else how could PVC pipes and joints stay watertight?
I don't know it that glue will stick PVC to polystyrene, sorry.
#7
Quote from: Caveman on May 25, 2016, 01:11:04 PM
.....Ive got a churchill firefly that I had bought with the express intent of turning into a land ship after being inspired by a landship I saw on here but since cannot find!
Maybe my land battleship below?  I built mine using a 1/700 scale USS Arizona and scratched up treads.  Inspired by a 1930's magazine cover.
Full thread with in progress build pictures here: http://www.whatifmodelers.com/index.php/topic,37605.0/highlight,land+battleship.html
I offer for consideration that using a 1/700 scale battleship for your hull and turrets would match up quite well for a 1/35 scale Churchill, or perhaps 1/1200 scale ship/turrets if your tank is 1/72 scale.  You can pick up some 1/700 scale or 1/1200 scale ships quite cheap.  Hull shapes can be tough to scratch build if you have not done it before.   Other hulls may work such as tug boats, or even toy type hulls, but it is nice to have the turrets and barrels from a kit.
Hope that help.  Good luck, the DEVASTATION is a neat looking ship.
Caveman
If I match the beam of the ship to the Churchill (1:72) the scale comes in at a bit less than 1:400. I've not really scratched much before so this will be a learning experience...
Caveman
Progress! Kinda. First turret roughed out. Pvc seemed to play nicely enough. I think the turret is a bit too tall at the moment. I'll need to take it down a mm or two.
GB isn't meant to start until 1st June
Caveman
proditor
Red seems to be the theme for the old land battlehsips.   :thumbsup: I did one a while back for the let it snow GB out of a Char Bis and a USS Alabama.
http://www.whatifmodelers.com/index.php/topic,28127.0.html
When it's that big why bother to camouflage it?
Caveman
Proditor, that's the one I remember! So this one is your fault :) not the false start though, that was all me...
