Italeri B-57G
Started by PR19_Kit, December 11, 2015, 01:18:37 PM
I've found I have one of the above, albeit a trifle knackered in that it only has one 'cheek' moulding, no idea why.
How good is the kit and what could one do with a 'single cheek' B-57 anyway?
Isn't the cheek piece an add-on anyway? I seem to recall you had to cut off the original nose to fit the cheeky nose. Or fit it over the original nose? I don't remember.  :unsure: Either way, the kit should contain a perfectly fine B-57B.
EDIT: Just looked at one of my B-57B kits and it seems Italeri used inserts for the different versions. The area that held the B-57G specific sensors and LGBs in the B-57G boxing has some additional HVARs and some dumb bombs in the B-57B boxing. So, yes, apart from some splodey bits, you have a fully functioning B-57B.
The one I have has the cheek bit as all-in-one  (IIRC)
It's a rubbish kit Kit.  Send it to me and i'll throw it away for you  ;D
The box of mine is in such a terrible state I'm not sure if some other bits have gone missing too. AND I don't have the instruction sheet to check with either.  :banghead:
Some deeper examination is called for I reckon.
I wouldn't want to burden you with the problem Fred, but thanks for the offer.  ;) ;D :lol:
Quote from: PR19_Kit on December 12, 2015, 03:05:05 AM
<...> AND I don't have the instruction sheet to check with either.  :banghead: <...>
High resolution pics of both the instructions and the kit's contents: LINK!
Quote from: ChernayaAkula on December 12, 2015, 10:49:10 AM
That's BRILL!  :thumbsup:
Thanks very much.  ;D
Supertom
It should be a single piece that has both cheeks. It mounts at the bottom.
Cool. Always wanted to build one of these myself
Quote from: Supertom on December 21, 2015, 09:19:05 AM
I'm afraid it isn't.
Having found the instructions it should be two handed pieces split along the centre line and they fit over the existing radome. Sadly I only seem to have the starboard half so it would look a bit daft if I built it like that.
Tophe would love it though.....  ;) ;D
van883
Quote from: PR19_Kit on December 21, 2015, 02:44:01 PM
i
I have a spare if you want. Pm me. Van
