avatar_Captain Canada
A400M
Started by Captain Canada, October 17, 2015, 12:56:45 PM
For the upcoming Logistics GB I was going to do a jet powered A400, using all the leftover bits from two A400 boxes. In 1/72 of course  ;)  I was planning a stretched fuselage for it too.
Mine is still coming along. Just trying to do at least 1 thing on it per day. She's getting there ! Added the refuelling pods and the boom on the roof. Lots of little decals are making it look pretty good !
I broke the main gear off so I could modify it. If you've seen some of my other posts I like to play with my toys. The gear will be removable once I'm finished. Nothing worse than trying to get from Ascension to the Falklands wit this gear down 😜You cannot view this attachment.
If the main gear's anything like that on the 1/72 scale version, you have my sincere condolences!
I had to throw most of it away on my 'Snoopy 2' A400M and scratchbuild each gear leg from styrene rod and sheet!
It was a little fiddly, but the fix will be easy. I plan on gluing a square tube in, and then a plate that all three wheel sets will sit on. Stay tuned.
The Revell 1/72 C-160 has the same problem as the A400M in many respects. Although a twin engine A400M would make a great whiff.
The boxes and new tube landing gear. The boxes will be glued in place and painted fuselage colour, then I can slide the tubes in and out. You cannot view this attachment.
Quote from: Captain Canada on October 25, 2022, 06:18:57 PMThe boxes and new tube landing gear. The boxes will be glued in place and painted fuselage colour, then I can slide the tubes in and out. [attach
GOOD thinking!  :thumbsup:
I should update my 1/72 A400M to a similar spec. A great idea  Cap'n.
Yet another example of the inverted sideways thought processes that make Whiffworld what it is.    Well done, Captain Canada!!
Independent steering on each wheel! Cool!
Installed and painted my little boxes. Looks good enough for me !You cannot view this attachment.
The little 'hat' I made for the front gear. It will be a decent representation of the gear doors once painted.  I had to make the oleo a little longer than I wanted to have the wheels sit on the ground. You cannot view this attachment.
Do you sing whilst you are building your model, "Two wheels on your wagon and I'm just rolling along singing my song" ?
