Four Bladed Props
Started by KJ_Lesnick, June 17, 2015, 08:18:10 PM
KJ_Lesnick
When did those first appear on US and British airplanes with useful effect
...right after the 3-bladed.
Nah. There were four bladers in WW1, well before three bladers came along.
Quote from: JayBee on June 18, 2015, 02:22:36 AM
There were two different types of four bladed propellers used. The first was to use two two bladed propellers with the second at 90o to the other blades and there was four bladed propellers made as one piece as manufacturing techniques improved but WWI was when they were first used. Sorry but I don't thing anyone can give you exact time and date or who it was, you will have to find that for yourself.
If one wants to be pedantic, four-blade propellers predate WWI.  ;)
KJ_Lesnick
Quote...right after the 3-bladed.
Well, I could have told you that: I was kind of thinking more like, when was the USAAF first able to make versions that could produce good net-thrust without excess drag.  The P-47C seems to be the first...
Are you referring to fixed bladed propellers or variable angled ones?    :banghead:
The USAAF didn't make propellers.
I'm not sure that a propeller 'makes drag' unless it's not rotating.
By definition it 'propels' the air backward (usually...) so the air can't produce a drag force as it's being moved past the blades, no matter how many there are.
Quote from: KJ_Lesnick on June 18, 2015, 05:38:47 PM
You mean the USAAC not the USAAF and if you could not tell that Captain Canada was making a joke then you need a sense of humour!
KJ_Lesnick
#11
QuoteYes
That's correct
Quote from: KJ_Lesnick on June 19, 2015, 03:21:21 AM
QuoteAre you referring to fixed bladed propellers or variable angled ones?    :banghead:
You mean variable pitch?
Yes.
Quote from: joncarrfarrelly on June 18, 2015, 10:34:16 PM
Can you clear something up for me Jon ? From what I've read the US Air Force (USAAC/USAAF) would order an aircraft from the manufacturer and then order the propellers separately from their manufacturer ? Is that correct or have I just miss-understood a couple of books ? Not sure if the USN differed in its practice ? Always seemed strange to me but I'd like to confirm or otherwise.
The engines, propellers, guns, radios etc. were BFE (buyer furnished equipment) that the customer
(War Department, Dept. of the Navy) supplied to the airframe manufacturer. So these items would
be contracted directly from the individual component manufacturers.
This is still true today e.g. on a commercial aircraft the engines, seats, galleys, lavs etc., are all technically BFE.
The airframer makes provisions in the base design for a variety of options, and prefers that customers
pick standard options, but the reality is that there is still a lot of custom work.  ;)
