Author Topic: Giant aeroplanes  (Read 2959 times)
Offline steelpillow
  • Just do whiffin', no snortin' inhalin' or sniffin'
    • Guy's blocki
Giant aeroplanes
« on: April 14, 2015, 05:15:56 am »
Apologies if this is not a new topic.
Some recent posts set me thinking, what is a practical shape for a giant aeroplane? Some of the design constraints, e.g. on the Airbus A380, are:
  • Exit doors positioned to allow quick evacuation in an emergency.
  • Wing root chord limited by need to evacuate.
  • Wing span limited by airport handling facilities.
  • Seat positions close enough to the aisles to allow quick evacuation.
  • Engines and fuel positioned away from the passengers, for survivability.
  • Huge inertia and scale require extra-powerful controls to respond quickly enough.
It is sometimes said that the flying wing airliner only makes sense on a huge scale. Some concept designs show a delta-shaped inner wing blending into slender swept outer sections. Engines typically mounted above the trailing edge. This is actually a rubbish idea that would never be approved because:
  • Emergency exits are a problem. They cannot be directly downwards as the u/c might have collapsed on landing, if it was ever lowered.  They cannot be directly upwards due to the need for injured passengers to climb up and also the time for that and to slide off the wing. In the leading edge they would need to be exceptionally precisely engineered, making them expensive, heavy and easily damaged. In the trailing edge they would need hugely lengthened doors that nevertheless could be easily opened by hand.
  • Engines above and behind would crash down on the passengers if they broke free.
  • Fuel safely stored in the outer wings would be a long way from the engines.
Some improvements could be made by moving the engines back to the traditional hanging leading-edge pods. This would allow upper trailing-edge exit doors to operate by dropping down onto the floor to open. But passengers at the front of the delta would still be too far away, so that has to be abandoned and a more traditional swept wing of greater span used. A smooth cranking of the wing to give outboard dihedral would shorten the otherwise extra-long undercarriage while raising the tips clear of the ground at takeoff. This is opposite of the A380's gulled wing - one might even have an S-dihedral, with the intermediate section of each wing having reduced dihedral. But the big problem remains, how to accommodate such a huge wing span?
Another approach would be to take the A380 a few steps further. It is designed for a stretched fuselage length, that's easy. But the fuselage width is limited b the need to avoid a deep auditorium-style room space, it is already taller than it can be made wide. A third deck would be a heavy, inefficient answer on such a fixed width. Better to add another fuselage or two. With the wing root chord and span already at the limits, some increase in the mid-section chord would help, also a lifting tail using relaxed static stability, a new foreplane so that the wing can be used more efficiently and possibly even a second wing in tandem, all beginning to look very like a Burt Rutan design on steroids.
So may I present a couple of concept whiffs:
Permanent soaring city A giant flying wing, this craft has no engines, but soars in the updraft found along Southern mountain ranges such as found in South America and New Zealand. It has an almost indefinite span, being on this scale flexible rather like some of the experimental ultra-lightweight solar aircraft. One can fly a new wing section up to it, bolt it on and then remove the ferry power unit.
Mega-liner Triple-hulled, tandem-winged four-surface airliner. 3,000 passengers, Six engines of near-double-Trent class. Fits within the 80m x 80m handling box of current major airports.
Cheers.
Offline Hobbes
  • Stores peanuts in his mailbox
  • What-IF SIG
    • Acme Engineering
Re: Giant aeroplanes
« Reply #1 on: April 14, 2015, 05:55:02 am »
Like this?
(from http://www.whatifmodelers.com/index.php/topic,7853.0.html)
That's a real-world proposal for a 3-fuselage VC-10  :blink:
Offline steelpillow
    • Guy's blocki
« Reply #2 on: April 14, 2015, 08:23:28 am »
:) Getting there. Note enough wings, not enough engines, not enough bigness yet.
Cheers.
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #3 on: April 14, 2015, 09:18:11 am »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline ericr
« Reply #4 on: April 14, 2015, 10:57:44 am »
strange : this time it's not quite the wingspan that got larger  :unsure:  :rolleyes:
Offline PR19_Kit
  • What-IF SIG
« Reply #5 on: April 14, 2015, 11:23:15 am »
Oh, but it did, albeit not by much.
I added some stainless steel -300 tips I found on ebay. That's AFTER I'd tested about 5-6 glues to see what would stick them to the styrene!  :o
Offline pyro-manic
  • Master Procrastinator
    • Me on Flickr
« Reply #6 on: April 14, 2015, 04:50:20 pm »
How about a passenger carrying variant of the Stratolaunch/Rutan Roc? Passenger pod instead of the rocket, and cabins in the fuselages as well. Not at all practical, but would be impressive. ;D
« Last Edit: April 14, 2015, 04:53:56 pm by pyro-manic »
Online rickshaw
« Reply #7 on: April 14, 2015, 05:31:33 pm »
Personally, I believe that giant, steam-powered airships offer the best solution to all your problems!  ;) ;D ;D
Offline pyro-manic
    • Me on Flickr
« Reply #8 on: April 14, 2015, 05:54:19 pm »
Well obviously, but the thread is "Giant Aeroplanes". :P ;D
Offline kitnut617
« Reply #9 on: April 14, 2015, 07:04:25 pm »
Lockheed did investigate this set-up, the model was displayed in their front foyer for a long time.
Offline Captain Canada
« Reply #10 on: April 14, 2015, 07:22:18 pm »
Love the triple....imagine seeing ( and hearing ! ) that take off ?
Offline KiwiZac
  • The Zac Attack is Back!
  • aka K5054NZ, proud Whiffer since 2005
    • Zac on Facebook
« Reply #11 on: April 14, 2015, 07:30:29 pm »
THIS I wanna see!!!
With warm regards from Whanganui, New Zealand
Offline steelpillow
    • Guy's blocki
« Reply #12 on: April 15, 2015, 03:16:31 am »
Ahh! The deck of a model warship grafted on top of a model Zeppelin, now that would be a whiff worth posting!
Mind you, one element missing from the designs I have seen is that all the deck fittings make the beast top-heavy. Essential to its flight stability are a couple of stub wings with powerful ailerons (or all-moving), linked to a Babbage engine to provide artificial stability. Naturally, the code for the engine was written by Ada, Countess Lovelace.
Cheers.
Offline Hobbes
  • What-IF SIG
    • Acme Engineering
« Reply #13 on: April 15, 2015, 03:21:04 am »
TomZ made one (a Zeppelin aircraft carrier) a while ago...
Online zenrat
« Reply #14 on: April 15, 2015, 03:35:40 am »
My name is Commander William Riker.  Take me to your women.
