avatar_trickyrich
Fantastic Plastic 1/72 Caprica Air Force Jet Viper
Started by trickyrich, March 01, 2015, 11:27:26 PM
trickyrich
Ok this is going to be my first build thread. This model is part of a Sci-Fi GB on another site but thought it'd be nice to show it here as well.
The model is a resin model (my favourite material) released by Fantastic Plastic, though I have a feeling it's origins are from someone else but can't remember.
This model was originally meant suppose to be the Caprica Air Force fighter jet but due to changes in the show, it was only ever seen as a virtual world fighter!
Here are some shots of the Viper from the artist who created it website. http://www.pierre-drolet-sci-fi-museum.com/viper-air-force
Well there is not a lot to this model but what is there is pure resin joy! It's moulded in a lovely cream resin with nice crisp details, no flash and best of all no bubbles......some pro-resin casting!
As you can see the details are quite nice.
Captain Scarlet is along for the build due to a slight mishap in the SPV!!!
Ok two things that do needs to be fixed though...
1, the weapons supplied wouldn't scare anyone!!! They look so under scaled for 1/72nd and pretty lame as well! So a couple of bit from the spares box and now we have something a bit more appropriate!
2, the cockpit & canopy, some work is going to be required here. First off the canopy is moulded resin which isn't that bad, it's just not very clear. I should vacform a new one, but I'm not too sure at the moment. But the main issue is that the canopy is too small for the cockpit opening! This will require a wee bit of work, at the moment I'm planning to move the canopy slightly forward and rebuild the back section. I want to maintain the correct profile so this seems the best way, plus I will need to do some detailing of the cockpit itself as it is a bit bare!
The main fuselage components have been glued together with nice clean joins just a quick touch-up with file/sandpaper required, plus a couple of bit of filler require in a couple of spots.
QuoteThe model is a resin model (my favourite material) released by Fantastic Plastic, though I have a feeling it's origins are from someone else but can't remember.
There's a big clue on the box as to the origin of the moulding ;D
Good idea on using it for something different, whiffing Sci-fi  :thumbsup:
Looking forward to seeing how this develops.
G
trickyrich
first update....I know I only just posted!
I normally can't help myself and I end up modding things, just because something about them bugs me! I hadn't intended to do too much extra on this project as I have too many others going on but.......I couldn't help myself!
First up there are a couple of small circle things on each side of the fuselage, don't know what they are meant to be but they weren't round so I decided to replace them.
A wee bit later and they look much better...still don't know what they are though?
Behind the nose intake there is a moulded cowling which didn't look that great, so out with some thin brass sheet and they were replaced. Looks much better, just need to be cleaned up.
The canopy as mentioned is too small. I wasn't sure how I was going to fix this. In the end I thought I'd try making my own. So using the original as the plug I vacformed a new one over it. It actually isn't too bad at all and is now the right size as well. This is only the second time I have ever tried this, the first time was the first attempt (plastic wasn't quite hot enough). Now I just that to sort out the rear framework for the canopy which should give it some extra strength.
Next the cockpit, which was quite bare. With the new canopy I could raise the seat up which it needed as it was too low. I boxed in the rear section of the cockpit plus made a back for the ejector seat. Plus did a bit of panel work in the front section, now it looks much better. Just need to now add some seatbelts, control stick, and gun sight before painting can start (seat and rear body work can just slip out to make painting easier.
The main air intakes had a slight gap and sat in a bit too much so some plastic sheet sorted them out.
Looking even better now!  Just a wee bit of filling required and some tiding up, especially around the new cowling section and the body will be complete.
trickyrich
Quote from: Thorvic on March 01, 2015, 11:38:41 PM
I know Anigrand did the mould work, which is as good as any I've had from them, but I thought this may have been released earlier by someone else? I fit was by Anigrand then I am an idiot!  :banghead:
perttime
Looks great so far!
I'd never heard about the Jet Viper. It is a good looking design.
Modelling_Mushi
Looking sweet. The vacformed canopy came out very well.  :thumbsup:
Very nicely done ! Looks like your canopy solution came out perfect !
:cheers: :tornado: :wub:
trickyrich
Ok with my break home I was been really slack with this one, mainly due to another build I just had to get finished, 1/48 CAC CA-13 Boomerang.
Plus I got a wee bit side tracked on all sorts of goodies I bought last shift, some Dust Models 1/35 beasts, a 1/35 Master Piece Models Hellcat, and a 1/35 Trumpeter E-100 Jagdpanzer! Believe it or not they are all for two dioramas I have plans for!
Ok I did do a little bit to this wee beast. The fuselage needed a little bit of filling around the engine intakes and nose intake, once dried this was sanded but, I will need to re-scribe a couple of bits but no big issue.
The rest of the time spent was again on the cockpit area, the canopy still didn't quite fit right and was a little bit short. So to fix both of these I cut the rear deck section off the canopy and made a new section from card. This will allow me to move the canopy forward a wee bit which will help with the fit and give me a bit more support for the canopy. If I can't get it right I may mount the canopy in the open position, seeing as I am doing so much work in this area it may be the way to go?
Sorry no photos this time...I forgot.
Once I get this canopy/cockpit sorted then the rest will be smooth sailing and pretty quick to complete.....I hope so as I have the P-38 STGB next on the bench, which starts this weekend and I'm host!!
Only 20 days of shift to go!
Diggin' the Viper. :thumbsup:  Dust isn't one I'm too familiar with, but I especially like the look of Konigsluther.
trickyrich
Well after what must be ages I have finally managed to get back to this one, a big push was made to get this one finished for the GB. Sorry this update will be very photo heavy!!
I had made quite a bit of progress since last update, I worked on this one while waiting for bits and pieces to dry on the P-38 build.
Finished up all the body work and gave her a quick undercoat before her final topcoat. Was really happy with the finish, though the instructions said it was only painted in the one colour overall it did look a bit bland. So a quick bit of masking and a splash of Neutral Grey and she looked much better.
All the other little bits and pieces were paint their various colours as well, once completely dry they were all be given a coat of clear before further detailing.
....and she's done!!!
I really didn't think I would finish this one in time, but out of the two builds I'm was working on she was the easiest to finish.
The final detailing was completed and the whole thing was put together. The only real issues was the decals, they were super thin, very delicate and are on one giant piece of film, which made life fun!
But in the end she was finished, and I am so happy with how she came out!! The "added" missiles suit her and the little bits I added make her more complete.....in my mind.
To any one wanting to build one of these...go for it! Just remember you will need to fix up the issues with the cockpit being too small, but other than that she's a lovely model...just wist someone would do a 1/48th version.
Plus the good news for me is that I have finished my crazy 3w/1w roster so will have more time for modelling again!!  :party: So next on the list of builds is a "ChompBot" (an Industria Mechanika resin model) and the B-51G "Tropic Moon III" beast!!!
Love it.  But what happened to Captain Scarlet?
Did that ever turn out nice. Love the look, seems like so many elements of differing aeroplanes....the weapons load is superb as well. Love the paint work too. Really well done.
