avatar_Weaver
Takom
Started by Weaver, December 26, 2014, 04:04:20 PM
Nick
I couldn't remember who'd done the M10 Panther, cheers.  :thumbsup: They'd look good together.  :mellow:
Takom 1/35 T28. Available in two boxings, prototype and postulated production.
More here:
https://www.themodellingnews.com/2026/02/preview-takoms-35th-scale-t28-t28a1a2.html?m=1
T28 Super Heavy Tank
M28 A1/A2 Super Assault Tank. 120mm or 155mm guns depending on the variant, with a barrel for the spares box.  :thumbsup:
Can I ask a dumb question ? What were the crane jibs for on the left hand side ? I can imagine one being for ammunition handling, but why two ?
Steel Penguin
they are the cranes to attach and remove the outer sets of tracks, so that it can be rail transported and not be massively out of gauge,  ( and you thought the problem that the Tiger tank had with its width was bad, its nothing on this beastie)  when its en route and dosnt need the lowered ground pressure, they are towed along behind it as a trailer.   i cant find a pic at the moment, but im certain it came up in one of the chieftains videos
But the US Turtle of doom!
i may have to get one as its certainly bonkers enough.
Quote from: NARSES2 on February 14, 2026, 05:15:56 AMCan I ask a dumb question ? What were the crane jibs for on the left hand side ? I can imagine one being for ammunition handling, but why two ?
As SP says, mating the outboard track set.  Lots of good information and pictures here: https://mikesresearch.com/2024/07/28/us-super-heavy-tank-t28/
Two different tank transporters, two different reactions to the weight of the Doom Turtle (from the linked site above)
M26/T67
M1070/M1000
Quote from: Steel Penguin on February 14, 2026, 06:00:44 AMthey are the cranes to attach and remove the outer sets of tracks, so that it can be rail transported and not be massively out of gauge,  ( and you thought the problem that the Tiger tank had with its width was bad, its nothing on this beastie)  when its en route and dosnt need the lowered ground pressure, they are towed along behind it as a trailer.   i cant find a pic at the moment, but im certain it came up in one of the chieftains videos
Also to fit inside LSTs.  Apparently with the outboard tracks attached, there was only about an inch clearance between the tracks and the guide rails.  More info about those tests in the referenced site above.
There's an option in the kit to pose the outer tracks in travel mode.
There's also options for the gun, suspension and tracks. Quite a lot of stuff to keep to one side for whiffery, which might help justify what imagine will be a hefty price as it's a large kit. You've also got the additional IR kit and drums with the M28 kit.
That is wild. Thanks for the link about this beast ! Very interesting stuff ! And of course, now I want one lol.
Six parts per link? Hundreds of links! I'll pass.
But you get a jig included!  :wacko: To be fair, it seems like the way they've done the sprue gates is handy.
I wish Takom would do World of Tanks turreted T28 prototype.  Talk about a whiff
Cheers lads. :thumbsup:
I thought they might have had something to do with the outer set of tracks, but then thought "but if so they'd need a set of cranes on both sides"  so how ??
Quote from: NARSES2 on February 15, 2026, 12:52:18 AMCheers lads. :thumbsup:
Crane mounting brackets on both sides of the hull. They'd just swap the crane from one
side to the other.
Quote from: kerick on February 14, 2026, 08:28:50 AMSix parts per link? Hundreds of links! I'll pass.
That's Takom for you.  Why make it one part when it could be four...
My guess is the crane is unhitched and switched to the other side when needed.  There appears to be fittings for it.
<beat me to it Jon>
Do they need a crane to move the cranes across?  ;D
Or just a whole bunch of squaddies to heave them over there?
