Been wondering about this
Started by maxmwill, August 08, 2014, 04:48:23 PM
maxmwill
In 1943, Boeing and Lockheed(Vega division) made a modification of the B17 by replacing the 1820s with Allison V1710s, calling it the XB38. While it was a bit faster, problems with the exhaust system and the increased need for the Allison engines for other aircraft, it never went beyond one prototype.
However, what if they stuck with the mod and decided to, instead of the Allisons, Merlins were used?
After all, there were bombers already flying with Merlins of various marks, and successfully at that, so information between the British manufacturers and Boeing/Lockheed could've rectified any squawks, such as the exhaust system.
I've been wondering about this ever since I ended up with two Halifax kits, one of the early marks, with the Merlin, and one with the Hercules.
I've seen models of the '38 before, but a Merlin powered Fort?
wagnersm
Makes sense to me.  The only question would be where to put the radiators, but I'm certain that could be worked out.
Steve
Those XB-38s were simply gorgeous. So I'm sure a Merlin powered example would look rather nice ! Isn't there a BF-109 engine B-17 on here somewhere ?
maxmwill
The radiators would be in the exact same place as on the Lanc, the Halifax, and the Wellinton bombers; that is, chin mounted, unless, and this'd be extremely unlikely, someone wanted an annular radiator, and the only power to do that was the Germans.
A chin mounted radiator makes the most sense.
Sure it does. A bolt on unit......the whole engine pod. Don't want to go messing around with the wing etc.
maxmwill
No, changes to the wings'd be minimal.
And, because I'm kind of a cranky mechanic, I might just make the attempt, seeing as I have an extra Halifax kit.
Now all I have to do is scrounge a 1/72 B17G(because the XB38 was developed from a G model), although an F model might suffice.
Then I'd have to come up with the appropriate color scheme, US or British Commonwealth, and a probably location(I'm thinking Pacific).
Be kind of interesting.
Packard Merlins, obviously.
I like this idea. Maybe a result of the R-1820's being more urgently required for something else?
...and a fifth engine would be nice also...
Quote from: maxmwill on August 08, 2014, 06:49:11 PM
You could try a semi-annular radiator as used on the Merlin 85s on the Lincoln?
maxmwill
I had forgotten about the Lincoln.
Is there a kit, or a resin conversion kit available?
Well, Britain had this concept on the agenda - at least one heavy fighter (with a Sabre, IIRC) was planned with an annual radiator. So it's not too far-fetched.
TallEng
darthspud
Looks like the Lincoln conversion makes for a better buy?
Well, it gives you lots of whif fodder on top of the 85's
maxmwill
I knew that.
When the Lincoln was mentioned, having forgotten all about it previously, in google images, there was a bit on a resin conversion kits, here:
http://www.martinsammodels.com/Webpage/Pages/Models/Reviews/Reveiws/paragon/Lancaster/Lincoln%20Conversion/Lincoln.htm
maxmwill
Quote from: darthspud on August 09, 2014, 04:54:33 AM
I realize that now, but, as I'm not  familiar with every type, which might not be as well known as most, although I do research some rather obscure other types, all I had been thinking of was around 1943, which was a year or so before the Lincoln first flew, and that had the concept that was behind the Allison conversion stayed reasonably prominent, with Boeing/Lockheed dropping the Allison in favor of current Merlins, what might have been the result?
I mean, if you want to consider something even more outrageous, instead of the later marks of Merlin, a Griffon conversion, in something a bit different than the Fort, say a B32?
I'm not even sure if there are any models of the Dominator available, or even the Shackleton, but the original inspiration for this was my realization that I have two different Halifax kits, and then started thinking about the XB38 and its problems, what could have resulted.
Isn't that part of the core of this forum?
