avatar_The Rat
Viggenize it!
Started by The Rat, August 06, 2014, 05:33:48 AM
Quote from: Scotaidh on October 22, 2023, 12:21:04 PM
Quote from: kerick on October 17, 2023, 10:45:40 PMThe Viggen parts are in the stripper bath. Yeah, go ahead and giggle.  :rolleyes:  He's a couple of pics of it taped together.
The wings look a little too far to the rear but changing that would be lots more work. Overall looks pretty good. I'm trying to use only the two seater parts from the Heller kit so I can build the single seater some day. I'm looking at replacing the Viggen tail fin with a new one in the shape of a taller F-104G tail. Hmmm, more work.
The F-104's tail, complete with stabilizer, would certainly add more 'wing' area, although I'd still want canards.  Thinking of canard aircraft, though, leads me to the IAI Kfir.  Besides all the wing areas, it also had, on either side of the nose cone, a flat trapezoidal surface, quite small, that was said to give a noticeable lift to the nose.
I red-circled them in this picture:
I've never noticed that before. Thanks! I'll look into it.
My tuppence worth: I prefer the look with the wings right where they are & the tail could be enlarged by removing it, adding styrene underneath it & shaping that to fit the profile, then re-attaching it.
That way you retain the "Viggen-ness" of the design.
thundereagle1997
Viggenize the F-111 F-106 F-105 & F-35.
thundereagle1997
Viggenize the A-10 Thunderbolt II.
Saab Draken with canards, a taste of what was to come.
JerrySyameimaru
Convair did in fact do research on the canard F-16.
Interesting, thanks.  :thumbsup:
Quote from: Scotaidh on October 22, 2023, 12:21:04 PMThinking of canard aircraft, though, leads me to the IAI Kfir.  Besides all the wing areas, it also had, on either side of the nose cone, a flat trapezoidal surface, quite small, that was said to give a noticeable lift to the nose.
I think that is just called a "Strake".
thundereagle1997
Viggenize the SR-71 Blackbird.
mexchiwa
Quote from: thundereagle1997 on August 15, 2024, 03:02:04 AMViggenize the SR-71 Blackbird.
I'm sure I've seen wind tunnel models of the A-12 in development that had canards
Beermonster58
Quote from: mexchiwa on August 24, 2024, 05:03:26 PM
You have indeed. This is a concept image of the A-12 that might have been  ;D
https://flic.kr/p/2qbZXeP
Quote from: Beermonster58 on August 24, 2024, 09:43:07 PM
And, it's not black.  Looks OK in graphite (?) but I reckon a dark  blue would really hit the spot.
>>LINK!!<< for when the token expires
Found on dA, what is, essentially, a Viggenized F-15-type fighter.  Although, I would have moved the canards to the top of the fuselage, as on the F-15SMTP demonstrator
Quote from: scooter on October 05, 2024, 10:58:12 AM
That one is saved for future reference! Thanks!
