avatar_The Rat
Viggenize it!
Started by The Rat, August 06, 2014, 05:33:48 AM
Quote from: kerick on October 17, 2023, 09:27:54 AM
Quote from: zenrat on October 17, 2023, 02:49:14 AMI have a Hasegawa Viggen.  I was thinking of De-Viggenising it
Phantom wings and phins?
This is sounding like a version of Trashcanistan.
No.  Phantom wings are earmarked for an F-15 (someone here did a drawing - it made an impression).  Viggen would keep standard flying surfaces but swapped over so the wings are in the "proper" position.
Quote from: zenrat on October 18, 2023, 02:58:01 AM
I'll have to keep that idea in my head for later!
Quote from: Old Wombat on October 18, 2023, 01:35:43 AMAnd, yes, it needs canards! ;D
Or maybe the wings just need forward extensions where they meet the fuselage ?
Quote from: NARSES2 on October 18, 2023, 06:02:23 AM
Some LEXs would certainly make it look different! I'll keep that in mind. I'm going to fill in and connect the Viggen hump (which I added way back when) with the area behind the cockpit. That will get rid of some of the banana look. I have to think up a good way of moving the wings and canards forward. The F-104 parts will get shortened.
Zero-Sen
Old one made after an idea of JPVeira...
Quote from: Zero-Sen on October 18, 2023, 12:48:02 PMOld one made after an idea of JPVeira...
Ahhh a F-16nized Viggen  :thumbsup:
Quote from: zenrat on October 19, 2023, 02:18:50 AMFalconised?
That's sounds like some form of coating for corrugated iron
Falconised steel  ;D
Quote from: Wardukw on October 19, 2023, 10:13:52 AM
Falconised steel  ;D
Quote from: Rick Lowe on October 19, 2023, 09:37:58 PMOr Falconised Rubber. :unsure:
Definitely some sort of heat treating, possibly through the application of very high velocity gases. ;D  ;)
Quote from: Old Wombat on October 20, 2023, 02:59:26 AM
Falconised steel  ;D
Gases released thru a couple of 3in steel tubes  ;)
And quite loudly  :wacko:
Scotaidh
Quote from: kerick on October 17, 2023, 10:45:40 PMThe Viggen parts are in the stripper bath. Yeah, go ahead and giggle.  :rolleyes:  He's a couple of pics of it taped together.
The wings look a little too far to the rear but changing that would be lots more work. Overall looks pretty good. I'm trying to use only the two seater parts from the Heller kit so I can build the single seater some day. I'm looking at replacing the Viggen tail fin with a new one in the shape of a taller F-104G tail. Hmmm, more work.
The F-104's tail, complete with stabilizer, would certainly add more 'wing' area, although I'd still want canards.  Thinking of canard aircraft, though, leads me to the IAI Kfir.  Besides all the wing areas, it also had, on either side of the nose cone, a flat trapezoidal surface, quite small, that was said to give a noticeable lift to the nose.
I red-circled them in this picture:
Zero-Sen
Who wants a mini Viggen ?
perttime
