Airfix fabric winged Mk I Hurricane
Started by PR19_Kit, May 16, 2014, 09:41:48 AM
There seem to be two of these kits around, one is A02067, which is the one I have, in 111 Sqdn. and Belgian AF markings, and the other is A01010, which seems to be in 85 Sqdn. markings.
But one is £2 more expensive than the other, so what's the difference between them?  :unsure:
01010 has one marking option, whereas 02067 has two. It's the same as for the Tomahawk/P-40 and Spitfire kits.
Ahah, thanks very much.
As I just need some extra plastic bits that's saved me £2.00  :thumbsup:
Yup basically as Pyro says but for £2 extra as well as the 2 markings options you also get the bits to make the cheaper boxing as well. So some bits for the spares box.
Quote from: NARSES2 on May 17, 2014, 12:45:41 AM
OK, now I'm confused again.  :unsure:
What plastic bits AREN'T in the cheaper one that ARE in the expensive one? The sprues don't look all that seperable to me.
major
#5
Apparently, sprue E is omitted, for the early MkI, from the cheaper boxing, seen here,
http://airfixtributeforum.myfastforum.org/viewtopic.php?f=408&t=41196
No doubt the bits you were wanting!
Cheers...Ray
Quote from: major on May 17, 2014, 03:14:36 PM
Cheers...Ray
Hm, that kyboshes my original scheme, which is a pity as I've just bought an A01010 based on the previous advice.  :banghead:
Having said that the bit I really needed was the 2 blade prop, but I may have a resin one kicking about somewhere. The taller rudder can be cut to size and the deepened rear fuselage can also be cut and sanded down I guess.
Quote from: PR19_Kit on May 17, 2014, 10:40:41 PM
Cheers...Ray
Kit I have that early Hurricane sprue - 2 bladed prop, short rudder and original keel knocking around if you want it ? 2 of my plans envisage latter Mk I's and only one will need the earlier fit
Interesting stuff....thanks for the heads up guys ! I guess buying both to get the markings ( for the stash and Belgian roundels always look so good ) and then buy a few of the expensive ones for more spares box filler !
Quote from: NARSES2 on May 18, 2014, 08:05:36 AM
That sounds  EXCELLENT Chris, thanks so much.
Now if only I could find that pesky Tigercat I said you could you could have when we were at the MK Show we could 'balance' the deal.  :banghead:
Quote from: PR19_Kit on May 16, 2014, 09:41:48 AM
£2, Kit.  Basic maths.  ;)
Cheers...Ray
Argh, apologies, Kit. I wasn't aware of that. :( I may have a suitable two-bladed prop if you need one...?
Quote from: Captain Canada on May 18, 2014, 08:51:49 PM
Capt and others lets be clear.
The more expensive boxing contains two markings options - 111 Sqd RAF and the Begian AF plus the extra plastic - 3 bladed prop, extended rudder and keel. This is the boxart http://www.hannants.co.uk/product/AX02067
The cheaper boxing contains 1 marking option - RAF in France 1940 and only the parts for the latter build aircraft - 3 bladed prop etc.. I.E. you do not get the 2 bladed prop etc. This is the boxart http://www.airfix.com/shop/aircraft/172-scale-military-aircraft/a01010-hawker-hurricane-mki-172/
So for early versions you need the more expensive boxing.
Thanks Chris. I checked my stash and the good news is, I don't have either boxing ! I don't think my LHS has them in yet. So I'll have to get one of each just to be sure that what you're saying is correct  :thumbsup:
PS-It's a pair of the newer mk. IIs I have in my stash.
Quote from: Captain Canada on May 19, 2014, 07:29:08 AM
There is no need to doubt Chris on this one Captain Canada. I have the more expensive boxing and Chris is entirely correct!
