avatar_Weaver
Want an injection moulding machine?
Started by Weaver, January 14, 2014, 07:28:36 PM
The machine is only half the story.  It's not going to be any use without moulds and they cost a real packet.
It might come in handy for that six engine bomber with contra rotating props.
Quote from: rickshaw on January 14, 2014, 09:02:12 PM
Full steel moulds, yes; metal-filled epoxy moulds as used in short run kits for decades, not so much.
loupgarou
Quote from: joncarrfarrelly on January 14, 2014, 10:54:54 PM
The small one uses silicone moulds.
As a matter of interest, does anyone have an approximate idea what the tooling costs are for the various different types of mould?
For the 1:24 Trabant, Revell spent something like €100k on the moulds.
Quote from: Hobbes on January 15, 2014, 08:02:15 AM
That would have probably bought the entire existing supply of REAL 1/1 scale Trabbies!  :o
Cheers - that's the sort of rough figure I've heard before. Scary isn't it?  :blink:
Sticky Fingers
Well, you could always pretend you make your own moulds... in 1/20 scale.
http://www.hlj.com/product/FNMMNK-101/Rsc
Quote from: Weaver on January 15, 2014, 11:52:48 AM
Yup, it's a lot of money. The Trabant is on the high end because it's a relatively large kit (lots of sprues and the car body means you need a deep, complex mould). Some of the money goes into engineering, making sure the liquid plastic flows well throughout the mould. The rest is milling and/or spark erosion on huge blocks of steel.
Quote from: loupgarou on January 15, 2014, 12:23:47 AM
... or aluminum, which means that it could probably use epoxy moulds.
Even a high rigidity silicone would flex too much for moulding a 'kit'.
The silicone does allow for limited undercuts and less concern over
proper draft when making patterns and moulds.
Ask Terry 'braincells37' Moore about 299 Models and the frankinjector moulding machine.  ;D
In a previous job we used a vacuum moulding machine, a souped up industrial version of a simple vacuum former that you might use to make a garage kit.  We usually just needed a simple shaped hollow to take a bag for a product, it would cost us £10K minimum, fifteen years ago.   Add in complexity and the cost would rise massively.  We could get thermosetting plastic moulds made that would do for a prototype, you were still talking a couple of thousand pounds.  If we were lucky, the company might absorb it into their total costs if we ordered the full moulds.
Quote from: Hobbes on January 15, 2014, 01:17:40 PM
It's a nice kit.  My neighbour gave me one he didn't want and I was surprised by the level of detail in it.  I'm toying with the idea of a Trabant/BMW 635 Mistel...
retro_seventies
For a relatively simple 2 piece aluminum mould, sized approx 7x5, we're paying around $4000 US.  Production is in China and turnaround isn't lightning fast, but the price and the product are more than adequate.
